Driveable???
Next weekend I'll be installing the following:
60# injectors 2 steps colder plugs 2.7" pulley watermeth injection Will I be able to drive it to a shop nearby to get it dynoed/HP tuned or will it not even run with those mods all added at once??? What should I do? |
Do not drive the car with 60lb injectors and no tune. You will be WAY TOO rich. More than likely, you will foul your plugs. Just my thought. :)
yea, i would deff. not drive it like that.
Then what should I do? get it towed over to the shop? If I buy a Maf-t would that help? If I scaled the fueling down would I be good to go to the shop??
The colder plugs will foul easier and with that amount of fuel you wouldn't make it out of your driveway ;) I would install everything except the injectors and save those for the shop parking lot *just make sure you can do it quickly* and dont boost on the way over there...
Yea, I doubt the car will run at all with those injectors on a stock tune, if you have the stage tune already, it will run...
| All times are GMT -4. The time now is 05:26 AM. |
