Eaton Superchargers Modification Guide
#77
Rattlesnake Race Shop
i never ported the scer and its ok .. btw i would like to do a swop with someone for some dyno runs...
meaning if theres a ss out the thats will in to do a base run with there charger then we will put on mine with the same pullys of corse and then run mine just to see the difference.. in boost and iat temps and so forth becouse i know that wasent the right way to do it but the sc that i have was broke in the corner where the triangle is and the little side port was so since it was broke i just cut the rest of it off so i could still use it.. i got the sc for 75.00 becouse it was broke the guy said he droped it and it hit something when it fell ... and he got a new one and i bought that one
#79
Always wondered how much boost can be attained due to porting. Is it realy measurable (IE port vs smaller pully), or more like regular(NA) port/polish; where it's good practice to get the most out of other mods?
I have a feeling the answer is more in between.
Edit:
And for that guy hacking up that SC... say what you will but you gotta admit that's alot of boost for $75. I wouldn't be against cutting such corners on an old spare/play vehicle. Though it may need more of a warning caption under it so folks don't go doing such things to perfectly good blowers.
Edit:
#82
#83
#85
#87
nice write up.. this is what i am thinkin i am going to do. i love jb weld, i use it all the time at my job. i might get 2 flat 1/8 of in inch think and jv weld that to the leak ports.. that sound like it should hold up? i think it will but i never played around with a sc before.
#93
http://www.fuckinggoogleit.com/
I believe it to be this, but I am not 100% sure. I am waiting on a reply.
http://www.dual-star.com/index2/Serv...xy%20Putty.htm
#95
unfortunately nobody here will be able to do that. Beyond this, there is no "good" way of doing it, all methods are just band-aids.. although some methods are better than others
mighty putty.. lol
#96
Find a raw casting.. weld them in.. reheat the aluminum to proper specs.. then machine the casting.
mighty putty.. lol
mighty putty.. lol
