Endurance racing LSJ Miata Swap
Old 05-16-2018, 07:41 PM
Hi everyone,
I need some recommendations. We are building an 02 Miata to endurance road race. I originally bought an LNF with transmission from an 08 solstice to swap into the car. We have since decided the tuning is going to be a nightmare. I now plan to buy an LSJ to use instead.
We will modify the supercharger snout to fit and add a cable throttle body. ECU will be a Megasquirt MS3 pro. All the cooling mods and a huge heat exchanger for the intercooler will be used. Fuel is restricted to 93 octane. Rev limiter will be set at 7k. Full 3 inch straight exhaust with header.
I want to get 240-250whp that can be beat on for 8 hours a few times a year. Can these motors handle that? What other mods should I do? I'd like to keep the longblock as stock as possible.
Am I asking too much?
Thanks
LSJMiata is offline
Old 05-16-2018, 09:08 PM
Personally if I was going to push it hard for 8 hrs at a time I would put good rods and pistons in it, crank should be ok. The last thing you want is engine failure. Now if it was only going to be an hour or something that's different.
63 Nova SS is offline
Old 05-16-2018, 09:23 PM
Maybe someone could chime in if the stock oil cooler can handle that. Seems to work well but maybe a external front mount would be nice.
I'd think if you kept the oil temp under control you'd be golden
Johnny Bliss is offline
Old 05-16-2018, 09:25 PM
I planned to do a remote front mount oil cooler. Forgot to mention it. Transmission and rearend will also have coolers, plus one for the driver 😉
LSJMiata is offline
Old 05-17-2018, 11:11 AM
Nova, if I have to do rods and pistons I would go the Le5/9 route and put an LSJ blower on it. How stout are the internals of the LSJ
LSJMiata is offline
Old 05-17-2018, 03:13 PM
Ecotec 3.0 for life!
RudyF_of_FMSR is offline
Old 05-17-2018, 05:46 PM
Internals are good, but to ask stock stuff to run close to flat out on many cars for 8 hrs at a time is asking a lot. It's not like you are hot lapping for 15 minutes and letting it set for 30.
Old 05-18-2018, 10:58 AM
mrbelvedere's Avatar
lol le5 internals
mrbelvedere is offline
Old 05-18-2018, 11:27 AM
Originally Posted by mrbelvedere View Post
lol le5 internals
I meant putting a forged rotating assembly in an LE5 if I'm upgrading internals
LSJMiata is offline
Old 05-18-2018, 11:37 AM
the le5 has a dog **** rod to stroke ratio 1.54 your best bet would be to run a lsj crank in a le5 block with a 2.2 rod raise the compression to 11.5 so you can keep the blower in its most efficient range and re sleeve the block with better sleeves then stock so you will be able to setup the piston to wall clearances and it will also give you better ring control and run a lsj head
Old 05-18-2018, 11:57 AM
Gotcha, I like the idea. I still have the LNF. Can it be resleeved to take 2.4 pistons?
LSJMiata is offline
Old 05-18-2018, 01:13 PM
No, you need a 2.4 block for 88mm pistons unless you wanna pay for big boy sleeves.
Slowbalt2000 is offline
Old 05-18-2018, 02:00 PM
Not a lot of advantages to the lower R-S ratio but there are some:
Shorter rods mean the overall height of the block can be shorter, which means the overall weight of the block can be lighter. The engine will typically pull more vacuum at low RPM, which means better throttle response and low end torque (good for street performance and everyday driving). Spark timing can be advanced a few degrees for some additional low speed torque, and the engine is less prone to detonation, which can be a plus in turbocharged, supercharged or nitrous applications.
Henry3959 is offline
Old 05-18-2018, 02:23 PM
Ecotec blocks are all the same height.
Old 05-18-2018, 02:32 PM
"Shorter rods mean the overall height of the block can be shorter"
Being the same was a manufacturing decision to cut costs.
Old 05-18-2018, 03:06 PM
you are right on rod to stroke ratio the higher the rod to stroke ratio is easier on the rotating assembly the piston side load on the thrust sides of the pistons a lot less then on a lower rod to stroke ratio the piston so you get a friction loss less wear on the rings and pistons and cylinders and rod bearings from less rod angle the acceleration from tdc is slower so it does not yank the piston down it also fills the cylinder better and will force a **** head to flow more air for better cylinder filling the old school way of lower compression for force inducted engines is just that old you raise the compression slow the blower down and keeping it where its most efficient will make you more money then low compression high boost
low rod to stroke ratio heavy rod angle accelerated wear on the thrust sides on the piston and rings and rod bearings higher piston speeds cylinder head does not flow as well and less cylinder filling its harder on the pistons and pins when going through tdc you raise compression and increase boost you just make things harder on the rotating assembly now you talk about running a short rod and shortening up the deck for weight loss on a overhead cammed engine when you bring the cams closer to the crank you retard cam timing so now you have to add a bunch of timing to make up for the slow cam timing and that can be hard on rod bearings as well
Old 05-18-2018, 03:07 PM
when a company does that they have to change the cam timing
Old 05-18-2018, 03:50 PM
Well thats not really a benefit then, now is it?
Old 05-18-2018, 05:25 PM
Not if we are being specific to the Ecotec block....
Like I said... Not a lot of advantages.
Old 05-18-2018, 05:41 PM
Edited above
Old 05-18-2018, 05:44 PM
I am sure those that are doing that as a weight saving measure are accounting for that as well.
Old 05-19-2018, 09:37 AM
In any engine I have ever seen built for rpm and efficiency the higher the rod ratio the better. Longer rods also allow you to use shorter pistons (wrist pin height) which saves weight, and makes the engine easier to rev and take rpm.
The 406 I have in the Nova came with a crappy ratio I went from 5.56 rods to 5.7 and if I wanted to do more clearance work I could have went 6.0. Cut down on piston weight, and allowed me to be able to spin the motor a little higher.
Old 05-19-2018, 01:35 PM
you cant account for the cam timing like your thinking a company like zzp probably could not account for it gm could
Old 05-21-2018, 04:55 PM
le sigh
07MetallicSC is offline
Old 05-21-2018, 04:59 PM
Originally Posted by 07MetallicSC View Post
le sigh
almost think we should start a thread just so people can argue engine theory and not muck up other peoples threads by going on a tangent, and scaring new members away.
Sharkey is offline
The Following User Says Thank You to Sharkey For This Useful Post:
07MetallicSC (05-21-2018)
Quick Reply: Endurance racing LSJ Miata Swap
Contact Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
© 2019 MH Sub I, LLC dba Internet Brands
We are a participant in the Amazon Services LLC Associates Program, an affiliate advertising program designed to provide a means for us to earn fees by linking to Amazon.com and affiliated sites.
