Endurance racing LSJ Miata Swap
07MetallicSC (05-21-2018)
I think I'm going to sleeve my LNF block, 88mm 10.4 cr pistons, head studs,zzp head, LNF crank, and a ported m62. I like the idea of an overrsquare 8000 rpm motor. I'll time the cams to push the peak hp a little farther up rpm range and try to run the stock blower pulley.
Is 240whp realistic?
I've been told and would just like to confirm that with a gen 3 you also have more strength so you can do a slight overbore for fresh cylinder geometry and proper piston clearance (with custom pistons). Is that correct? If so, that is my plan for the next engine rebuild. If not I will re-sleeve a cheap lsj block with those higher strength sleeves that are available.
every low mile gen 3 block I have had my hands on the bore was out of spec the block may be stronger but the cast in place sleeves don't seem to be that great
