Finding different sizes of belts
Just wondering where i can find belts for our car? Local parts places are carquest napa autozone and checker. Only place that could order belts was carquest but they only have 2in bigger and 9in bigger. I really need a 6" bigger belt or so to fit the second alt... Im going stage 2 and 2.9 to help and we built the alt bracket so the alt can move a bit but i dont think im going to get that 2" bigger belt to fit reguardless. any help is appriciated
dizzam, good question- what are your options for mounting the second alternator? maybe you will have to fab a bracket so the pulleys match the belt sizes...
why are u running another alt? just get urs re wrapped and up the amperage (dont pay more than 1$ per amp) and run 2 optima yellow tops and split ur system off of the car battery
Originally Posted by Mnatvyc1223
(Post 1726659)
Originally Posted by Raven SS
(Post 1726662)
(Post 1726662)
oh ya for all you preformance guys that are freaking out about me loosing power ect we calculated the alt will have a max strain of 5hp on the engine and im pretty sure the extra weight im adding for the system is going to hurt more then the alt. So any ideas belt wise? I really dont want to try this out and be just barely off |
The dual rib belt (ribs on each side of the belt) are only made for certain requested sizes, the requestor has to pay to make a certain number of belts. That is why there is limited production of these belts. Pulleyboys made a belt tensioner with 3 settings on them stock, 3.0, and 2.8 you might want to check and see if this might work with one of the belt sizes you are trying to work with...
well not really... its a sorta odd configuration were going for here
also i had a feeling the reason for the shortage of belts was the dual ribed part but theres gotta be something else out there |
Would be interested in pics. Man i remember them days now i dont have time to do nothing regarding my stereo systems anymore, i just got rid of my extreme van :-(. I hadnt got my term lab meter back working so i dont know where im at now but i have just through everything in. Have you looked into Stetsom amps?
They put out alot with alot less current draw. I plan to run two 7kd's and im still running T3 subs. |
| All times are GMT -4. The time now is 11:30 AM. |
