Glowshift
Glowshift
I just got and installed a triple pod and gauges from glowshift on my 2005 lsj. I just wanted to say anyone who is thinking about getting them, go for it. I also wanted to say the glowshift company treated me well. I think we should have more product reviews on the net!
I got boost, volt, and air to fuel. Got the optional wiring kit for like $7 extra well worth it. The only thing I don't have that I thought I was getting was a wideband bung. but no big deal. They look SICKKKKK
easy install, standard wires power, ground, signal, dimer
I have the boost gauge to with 7 colors. mines not tinted tho, overall I like it prolly gonna get one of there wide bands next.
Here is a link to the pod
Universal Triple Gauge Single Din Radio Face Pod
I had to modify it a bit to make it fit behind the double din face plate
if you look from the side you can see where I trim some metal off to make it fit
ok I have to ask why you are hating on geting a tune with it? I was tuned with my glowshift wideband and I have had zero problems
Who knows if that sensor actually reads even close? And to top it off if you ever have issues with getting bad readings the companies first response is clean the sensor with brake fluid, which will pretty much ruin the sensor but make it give somewhat reasonable looking readings for a little while that are actually junk.
on another note yes it does look trashy when you look behind the seans but when its all together it looks exactly the way I intended it to look, hidden and low profile and I have goten many compliments on doing it like this insted of the ricer piller of doom
if your refering to mine the water temp was for the heat exchanger but now it is an oil pressure gauge :P and I put the wideband where the boost gauge normaly goes and I got a glowshift boost gauge so it would match with the others
but yeah I already knew glowshift offered a complete piller replacement for our cars its just not my style and in my experiance if a cop pulls you over they see that and automaticly think your a street racer
talk is cheap post link or stfu
There is an even better one for like 200 bucks, I remember seeing a link to it on a forum on here a good while back.
Better then the ricer volt gauge lol
