GM stage 2 dyno
Old Apr 13, 2006 | 10:32 AM
  #51
Darksun's Avatar
Originally Posted by SS_SC_Cobalt
I was just about to post that, for example a mustang dyno of a STI is around 200-210whp, on a dynojet, it is 240-250 so you are right there
NICE TO SEE FINALLY SOME HARD NUMBERS!
248hp with stg 2 and a CAI, NICE!
about 270-280FWHP!
nah hes in the mid to high 250 range but even thats more than respectable from these kits
Old Apr 13, 2006 | 11:11 AM
  #52
mrbelvedere's Avatar
Originally Posted by BLKSS
I have my dyno sheet right here but I dont know how to show you guys. I scanned it and all but I only got 220hp 194 torque. ..
hey blkss ive seen me buddies car dynoed on a mustang dyno and a dynajet on the same day and there was 35 hp difference on the car between the 2 dynos dynajet is the dyno you want to use its the most accurate one out there
mrb
Old Apr 13, 2006 | 01:36 PM
  #53
freakaccident's Avatar
Really? I wove you man!
Yeah. You are probably in the 240whp range. Mustang dynos suck if you wanna see good numbers. They calibrate weird too so one might be 10% off from another. If you want to compare CAIs then a Mustang will do the job. Dynojet is the public's standard.
Old Apr 13, 2006 | 02:39 PM
  #54
jerm's Avatar
I believe Mustang dynamometer actually introduce a load on the dyno cylinders. This is to compensate for road drag and wind resistance. Dynojets calculate the power without these extra variables. Neither of them are bad; as a dynamometer can never be 100% accurate due to too many variables in the world (wind, geography, temp, etc). What it boils down to is 1/4 mile times (then again these are subject to those same variables).
Old Apr 13, 2006 | 05:03 PM
  #55
2K5SS/SC?'s Avatar
BLKSS - I dyno'd at 200whp and 177 ftlbs on a Mustang Dyno with just an intake. I should have My Stage 2 installed tonight, and reflashed in the morning. I also put an exhaust on, but I'll still dyno it and keep you posted.
Old Apr 15, 2006 | 01:30 PM
  #56
distillion's Avatar
my dyno was similar, but he told me it was old dynojet machine and it acts more like a mustang dyno so i got 233whp, then he said to add 10 more horses to that because other dynojets dyno 10 more horsepower more than his so that puts me a 243 giver take, and i dont ahve an intake, he told me i need one desperately and i should see better gains, and i was also runnin on a hot engine and the fan was used at the very last run, but all in all the stage 2 kit is worth it...my runs were in 4th gear as well., i asked him about stock ss's dynoing around 230ish and hes said the car is underrated but alot of dyno guys paly with numebrs to satisfy the customer, he told me he can take 2 min and give me 265 but thats just wrong and hes never seen an ss sc at 230ish stock, he showed me a stage 1 ss dyno and i have much more torque and about 8 horses more so when i get my intake and motor mount im gonna go again and see what it gives me, im also thinking the gm honed maifold cuz i can get a super deal on it, with sayin all that sweet numbers man! lol
Old Apr 15, 2006 | 01:32 PM
  #57
TheToolmaker's Avatar
hey toolmaker,
What tempature where you running at? humidity? Btw I did run at 7000 see the dyno chart its useless. I peaked around 4800rpm.
I don't know what the humidity was but it was around 80 degrees.
Old Apr 15, 2006 | 01:54 PM
  #58
BeermanSSSC's Avatar
Originally Posted by Brian MP5T
So basically, the Paranoia about Stg II being crap are in fact Crap!
Good Solid Numbers for a Bolt On!
Wasn't it you that was one of the first to crap on the gm kits?
Old Apr 15, 2006 | 02:05 PM
  #59
TXRLU's Avatar
For comparison
Here's a dyno of my LSJ with only K&N Typhoon for comparison purposes.
If its too small for you to read: 213.4 max HP, and 197.5 max torque. I've since put on a smaller pulley and expect stage I in a few weeks..........
Old Apr 15, 2006 | 02:11 PM
  #60
distillion's Avatar
so you made just over 200 ponies stock and the intake gave u roughly 10 ponies, not bad
Old Apr 15, 2006 | 05:36 PM
  #61
TXRLU's Avatar
? who mine? Well, that's assuming that GM didn't UNDERRATE the LSJ which those in the know...........
Old Apr 15, 2006 | 05:38 PM
  #62
ninja44's Avatar
You go to TAG? That Stage 1 may have been me and after I saw the dyno numbers I am all the more skeptical of dynos as an all out HP measuring tool. I can definately tell you that 5 more pouinds of boost is gonna give me more than that. I had a dyno with 3.15, I/E and it put down 238HP on another dyno (was free), now after Stage 1 and a 2.9 pulley it puts down 230 at TAG's dyno??? My ass meter measures HP in the 1/4 mile and 5 more MPH is where it's at.
Old Apr 15, 2006 | 05:44 PM
  #63
distillion's Avatar
ya i went to tag and i totally agree ith you, even he said it himself, other dynos(dynojets) get higher than his cuz his machine is an older version, he told me it acts more like a mustang dyno, so it is kinda sketchy thats forsure.
Old Apr 15, 2006 | 06:10 PM
  #64
TXRLU's Avatar
Butt dynos probably give better torque readings than HP readings. You have to remember, torque is what you feel while HP is the amount of work done through a given interval. Yes they both work together, but I think too many people look at HP and expect to immediately translate that into acceleration figures. Would be nice if it worked that way, but it doesn't. What I look for in an engine's dyno chart is a long flat torque curve. The LSJ definitely has a nice square looking torque curve. If you have a Dyno chart of your car, study the dyno chart (pay close attention to the gear at which you ran the Dyno Run) and run it through the gear completely, any spikes you see on the Torque curve (i.e. any sharp increases or decreases) should be evident during your driving through the gear. I notice around 4K or so I get thrown into my seat a little more. Sure enough, around 4K is where I notice the Peak Torque on my Dynosheet occurs.
This is a decent article, but still kinda tedious to read http://www.houseofthud.com/cartech/t...horsepower.htm
Old Apr 15, 2006 | 06:33 PM
  #65
distillion's Avatar
all i know is the car pulls really hard now, thats all that matters, now i just gotta make it breath a bit better and get ready for a clutch sometime in the future and its all good.
Old Apr 15, 2006 | 09:13 PM
  #66
TXRLU's Avatar
Plan on putting any bushings in to help with any possible wheel hop? I started getting some awful wheelhop of late, went with a wider tire and the wheel hop is all but gone. One thing I didn't think of though, is going down to a series 40 since I went wider. Car looks weird with a higher sidewall, of course that might explain why the wheelhop is gone.
Old Apr 15, 2006 | 09:15 PM
  #67
distillion's Avatar
pertty much no wheel hop for me, got the poly bushings, gettin a poly engine mount just incase though from jbp.
Old Apr 19, 2006 | 09:44 PM
  #68
badassredcobalt's Avatar
Hey man i would like to know more about this guy at hoosier performance id like to get the v-afc II controller installed seeing if u can help me, email me at robert.formeck@us.army.mil
Old Apr 19, 2006 | 10:02 PM
  #69
97CIVIC's Avatar
Originally Posted by Mercury
That doesn't look that bad at all. I can't wait until I get stage 2, I hope it will put me in the mid 13s!
FOR THAT YOU NEED AN CLUTCH UPGRADE TOO
Old May 28, 2006 | 02:09 AM
  #70
Psykostevo's Avatar
***** fucked up. Considering I spent 1700 bucks on this thing. I know the kit works like Denny said its just the gains arent showing.
GM stage 2 costs $895 dollars installed here in Phoenix, $1,700 sounds like a ripoff.
Old May 28, 2006 | 01:10 PM
  #71
mikeg's Avatar
I just installed some mods and was wondering if anybody has the same mods with dyno numbers? GM stage 2, GMPP honed exhaust manifold, GMPP cat back pipe, Injen intake.
This car kicks ass and sounds crazy. any help would be great.
I have seen a dyno on the ex man and pipe and it was a 30 hp gain. I also have seen a dyno on the injen intake and the gm stage 2 it was a 45 hpg.I have not seen all togather .
could my car be at around 280? iI tell you what it sure feels like it!!
Old Nov 28, 2007 | 12:11 AM
  #72
EEEEroc's Avatar
i have similiar mods on my cobalt i just bought so i really hadnt had a chance to really play with it. i do have a stage 3 pulley on it, and high flow cat.
Old Nov 28, 2007 | 12:44 AM
  #73
rukkee's Avatar
lol , i remember reading all of these , i lingered around here long before i joined . Stage 2 for the SS/SC had the same aura and speculation surrounding it that the SS/TC now has .
Jan 12, 2016 12:01 AM
HEATON
Oct 16, 2015 07:21 PM
maliki778
Oct 1, 2015 07:39 PM
Sep 27, 2015 08:53 PM
grampss
Sep 27, 2015 08:51 PM
