GM stage 3 ????????????
Old May 16, 2011 | 01:45 PM
minizr1's Avatar
Hey guys. I'm thinking going GM Stage 3. What's the difference between the two? Does either of them up the fuel delivery? I am thinking of buying a gm stage 3 pcm from some one, and I have a set of 60 lb. injectors. Will GM Stage III even utilize these? I know that it has an adjustable rev limiter. I've also heard that there's a boost cut-off @ 12.5 psi. Please help.
Old May 16, 2011 | 01:47 PM
Sylver01's Avatar
From what I've read Stage 3 is a slightly smaller pully, 2 octane settings, AC disabled(Unless you get trifecta's stage 3) and a setup in the ECM for nitrous
Old May 16, 2011 | 01:55 PM
D_Rob's Avatar
You need to read the stickies. Not trying to be smart, but this is covered very thoroughly there.
Old May 16, 2011 | 01:57 PM
minizr1's Avatar
isn't there a stock a boost limiter with a stock tune though?
Old May 16, 2011 | 02:10 PM
Staged07SS's Avatar
Administrator
Administrator
There is no boost limiter/cut with GMS3.
I have been running the GMS3 PCM for years now.
GMS3 is an upgrade to GMS2. It comes with a smaller pulley 76mm vs GMS2 77.9mm, dual pass endplate, unique PCM with an adjustable rev limiter, high octane mode, and the ability to run nitrous.
The GMS3 default 93 octane tune is much more refined/better than the GMS2 tune. It commands a leaner AFR (11.3) & 21-22 degrees of timing. High octane mode adds an additional 4-5 degrees of timing.
GMS3 is setup to run 42 lb/hr injectors, but if you get a custom Trifecta tune you can run pretty much any setup you want while still retaining the great GMS3 features.
Old May 16, 2011 | 02:39 PM
Sylver01's Avatar
Do you have the GM stage 3 or the trifecta stage three?
Old May 16, 2011 | 02:41 PM
troyss's Avatar
If you run gms3 does it take out the AC?
Old May 16, 2011 | 02:44 PM
Staged07SS's Avatar
Administrator
Administrator
GM Racing Stage 3 PCM with Trifecta unlocked A/C
Yes, as it comes from GM Racing, but Trifecta can unlock it for you.
Last edited by Staged07SS; May 16, 2011 at 02:46 PM. Reason: Automerged Doublepost
Old May 16, 2011 | 04:03 PM
minizr1's Avatar
Cool, but is there one on the factory tune?
Old May 16, 2011 | 04:09 PM
troyss's Avatar
**** sounds like the gms3 pcm is way better then zzp
Old May 16, 2011 | 04:22 PM
minizr1's Avatar
Right! Gm stage 2 is thoroughly covered. Not 3....
Old May 16, 2011 | 06:57 PM
D_Rob's Avatar
Now I am being smart. LAST PAGE OF THE FAQ YOU WOULD SEE MY POST. It says this
Originally Posted by richards_usmc
i heard from some one that the upgrade kit from chevy for the 2.0 supercharged is like under $500.00 and ill bump me from 205 hp to 460 hp if there any trueth to this or is it bullshit.
WOW guy. See post number 634. It's just a few up before yours."
And the post I'm referring to, says this
I just read the last few pages of the this thread, and it is question after question. If people would read from the beginning of this thread, all their questions would be answered. I am by no means trying to be an *******, but people need to do a little research of their own.
Cliff Notes (common answers to questions):
What comes with a GM Stage kit ?:
-GM Stage 1 = 42 lb/hr injectors & tune
-GM Stage 2 = 77.9mm pulley, hub, shorter belt, 42 lb/hr injectors, & tune (same as GM Stage 1 tune)
-GM Stage 3 = 76mm pulley, new pcm/tune, dual pass endplate, & uses injectors from GM Stage 1/2, & hub from GM Stage 2.
Are GM Stage kits covered under warrenty ?:
-GM Stage 1/2 are covered under warrenty. GM Stage 3 is for off road use only (no warrenty).
How much boost do the GM Stage kits make ?:
-GM Stage 1 = 12.5psi (same as stock)
-GM Stage 2 = 15psi (on avg.)
-GM Stage 3 = 15.5-16psi (on avg.)
How much horsepower do the GM Stage kits produce ?:
-GM Stage 1 = 236hp & 205tq
-GM Stage 2 = 241hp & 218tq
-GM Stage 3 = 248hp & 260hp w/ 100 octane & 310hp w/ nitrous
*All GM Stage kits can/will make further power with the addition of supporting mods ie. intake, exhaust, cooling.
How much quicker will my GM Stage car be ?:
-GM Stage 1 = 0.3 sec quicker in the 1/4 mile than a stock SS/SC
-GM Stage 2 = 0.7 sec quicker in the 1/4 mile, & 0.5 quicker to 60 mph than a stock SS/SC
-GM Stage 3 = No numbers from GM, but I have managed 0-60 mph in 5.2 sec, but I'm also fully bolted. A standard GM Stage 3 car would prob. knock a tenth or two off of the GM Stage 2 1/4 mile times, and prob. be a tenth quicker to 60 mph on 93 octane mode. On high octane mode or nitrous, it would be much, much quicker.
There, I did it for you.
Old May 16, 2011 | 07:00 PM
D_Rob's Avatar
While we're at it, here's the info you will need for Trifecta from Pyros777 (I'm back to not being smart). https://www.cobaltss.net/forums/2-0l...-3-faq-214518/
Good info there right at the top. Hope it helps.
Old May 16, 2011 | 08:30 PM
Staged07SS's Avatar
Administrator
Administrator
Thanks for posting that for me man!
Old May 16, 2011 | 08:51 PM
Rocky87's Avatar
i have to get a stage kit for my car!
im starting to feel left out
Old May 16, 2011 | 09:19 PM
D_Rob's Avatar
Ha ha ha. No problem. It's a good post
Old May 16, 2011 | 10:11 PM
ssblacksc's Avatar
wow mini you should be coming right along with your car. I am sure that trifecta can tune everything that you need into your stage 3 pcm. With these cars if you have the money and more money, someone will hook you up lol! Good luck. The harness should be there Tuesday. When I drive down to SC I'll have to stop and see your car.
Old May 16, 2011 | 10:58 PM
minizr1's Avatar
Thanks d rob! Can't wait for the harness!!!!!
DarrenGC
Dec 24, 2021 01:55 PM
HEATON
Oct 16, 2015 07:21 PM
nathan112i
Sep 30, 2015 07:12 PM
grampss
Sep 27, 2015 08:51 PM
