Header/Dp need help
i got gss to install my header/dp but it seemed like getting exhaust leak from where header/dp connect. Correct me if im wrong shouldnt there be a gasket in between they stuck some red shit in there but it didnt seem to seal.
bump need to know soon cause i wanna have it running perfect by tomorrow for cruise weekend |
Absolutely there should be. Should be both a gasket on both sides of the downpipe.
Originally Posted by Backdrift
(Post 4231366)
Yeah, the DP/Header is not hard to replace your self. Make sure the bolts are tightened well, because when I put on a temporary flex replacement earlier this month, the bolts were no where near tight enough, causing it to leak.
I've seen that happen with a few people, because people are typically cautious tightening those bolts in fear of cracking the gasket. |
(Post 4231401)
hey guys another question can i reuse this gasket?
http://i339.photobucket.com/albums/n...1/P1000043.jpg |
ya as long as its not bent or cracked or broken anywhere, just inspect it throughly
Ha Ha
Originally Posted by Rippin07
(Post 4233831)
Ha Ha
