HELP!! Dual Pass Laminova core positioning
I have found a few how to's and they have different pictures about which way to put the cores. which is better?
A (Source): https://www.cobaltss.net/gallery/fil...0/CoreFlow.jpg or B (Source): https://www.cobaltss.net/gallery/fil...tled_55665.jpg or C: It does not matter? |
if your goin dual pass go with the first pic but swap you flow directions
it all depends on what way your going top run the coolant in the plate. the idea is you want the coolant going into the small holes in the cores and comming out the big ones. i run the coolant into the center of the plate and out the 2 outer fittings, and that being said my cores are setup like the 2nd pic.
OooO contact ebristol on RLF for details.
Originally Posted by Sharkey
(Post 4219191)
^^^ assumes two inlets and one outlet... (i think)..lol
If you read the gm suppplied instructions.. the picture and the text instructions don't agree... LOL.. |
^^^ thats a cool pic
Originally Posted by lsjwannabe
(Post 4219521)
source b
For the curious, From the laminova engineer himself:
The plugs in the centre hole of the cores normally should be located on the coolant inlet side (upstream). If there not, in most applications it should not be any problem. For some applications, the plug can come loose, but only for high system pressure applications. Best regards M**** A***** Project Engineer Laminova Production AB Värmdövägen 120 SE-131 60 Nacka Sweden |
Thanks for the help everyone!
if your running dual pass...ur picture B is the correct way of doing it....the little holes are inlets, so they go on the inside, since ur inlet is in the center, and the bigger holes r outlets, they go on the outside bc the top and bottom tube are outlets...so once agian picture B is the correct way of doing it
see thats what this forum is about...
great advice from people who know what they are talking about. |
http://i247.photobucket.com/albums/g...3/dualpass.jpg
that will tell u how to run the hoses goin to and from the manifold..if you dont have a filler tank and are still using the factory filler neck, than pretend the tank is a neck : p same concept applies, inlet comes from manifold, outlet goes to your h/e |
Originally Posted by Jn2
(Post 4223207)
that will tell u how to run the hoses goin to and from the manifold..if you dont have a filler tank and are still using the factory filler neck, than pretend the tank is a neck : p same concept applies, inlet comes from manifold, outlet goes to your h/e In short, your shit is backwards son. Though, your pump isnt really illustrated properly. |
Originally Posted by StreetDreamz
(Post 4223352)
Assuming that your pump is wired correctly, you are sending the hot coolant up through the manifold, and in the outlets of the laminovas and out the inlets of the laminovas, then through the overflow, then into the heat exchanger, then back to the pump.
(Post 4223457)
the pumps outlet faces upwards, the inlet ifaces away from the pump, i know i drew the in let off a bit :p but you should be able to figure it out....
ah the tank yes, i see what u mean lo, yeah bypass the tank :p pretend its the filler neck :) thats how mine is done
I know, same thing though. You are just substituting the stock overflow for the bigger resovoir. Fluid should still flow the same direction though.
yup yup
:cussing: I give up.
Hey, source b is a pic from my install. How'd that get there. LOL.
