Cobalt SS Network
Cobalt SS Network (https://www.cobaltss.net/forums/)
-   2.0L LSJ Performance Tech (https://www.cobaltss.net/forums/2-0l-lsj-performance-tech-47/)
-   -   HKS BOV questions (https://www.cobaltss.net/forums/2-0l-lsj-performance-tech-47/hks-bov-questions-314545/)
The Rookie24 Dec 7, 2014 10:14 PM
HKS BOV questions
ok I've looked through the forums on here but can't seem to find my answers
this is my first turbo build I'm swapping my lsj to turbo btw.
1. is the HKS reliable i keep seeing back and forth on this
2. i plan on using zzp charge pipes are there a better options for this bov
3.ive seen some ppl say the flutter sound is just something these bovs do but that does not sound right
thanks guys
The Rookie24 Dec 8, 2014 11:04 PM
Anyone??
OzzyruleZ Dec 9, 2014 01:12 AM
I'm assuming the HKS SSQV? I don't have a Cobalt anymore but I've been running a SSQV on my 300ZX for about 8 years now with no issues.
blueLNFftw Dec 9, 2014 08:02 AM
make sure you get a real one; there are tons of fakes
The Rookie24 Dec 9, 2014 02:08 PM
yea the ssqv does your ever make any flutter sound did you do any modifications for it to work correctly or did it work correctly first install ? and yea I've seen there are tons id buy directly from them most likely
blueLNFftw Dec 9, 2014 02:10 PM
You need to do a MAF relocate and tune for it.
user 72239 Dec 9, 2014 02:28 PM
I have an SSQV4
It flutters on low boost. sounds awesome
However at WOT or higher boost i.e <15 psi it blows off like normal.
The Rookie24 Dec 9, 2014 03:55 PM
where is the maf relocation go on the cold side of the intercooler before the throttle body ?
and isn't the flutter damaging to the turbo? i only plan on mid 300s with my swap till my engine is built
OzzyruleZ Dec 9, 2014 04:02 PM
Mine does have a little flutter at really low boost I can't really hear it due to where I have it mounted though
user 72239 Dec 9, 2014 04:07 PM
Originally Posted by The Rookie24 (Post 7451546)
where is the mad relation go on the cold side of the intercooler before the throttle body ?
This is a common misconception.
Turbo flutter is NOT bad for your turbo. Even stock turbo, stock BPV cars have turbo flutter sometimes.
What IS bad for your car is surge. Surge is when the turbo is flowing more air than your head can ingest at a given RPM, and it doesn't sound anything like Flutter
The Rookie24 Dec 9, 2014 04:13 PM
i found 2 vids of the same balt with hks
this one he has flutter
this one he says he fixed it and u can hear the diff but he doesn't say how anyone know him ? on here
is he having surge in the first one?
user 72239 Dec 9, 2014 04:26 PM
What it sounded like was he kept his stock BPV hooked up and then hooked up his BOV
I'll make a video of mine when I leave here in about an hour to show you
The Rookie24 Dec 9, 2014 06:57 PM
the vid description in the flutter one says he has the treadstone block off plate does that not remove the stock bpv and thanks look forward to seeing the vid
taintedred07 Dec 9, 2014 07:13 PM
I have the hks and the stock bpv, working with eachother since the charge pipe I picked up had it on there. We just t'd into the vacuum line running to the manifold, no blockoff plate.
blueLNFftw Dec 9, 2014 08:04 PM
Sounds like a bad way to do it.
taintedred07 Dec 9, 2014 08:08 PM
Works fine and it was the only way I could set it up without flutter. I followed a how to on here that explained setting up the bov without a blockoff plate, but they t'd the line from the bpv into the line going to the charge pipe - so it'd be closed during boost ect. And then connect the bov originally where the bpv plugs into on the solenoid on the manifold.
For me anyway, just teeing into the vac line coming off the solenoid into the manifold worked best and the bov works in conjunction with the bpv. I can post a video.
blueLNFftw Dec 9, 2014 08:13 PM
Flutter is fine.
Surge is bad.
user 72239 Dec 10, 2014 10:53 AM
I have my HKS connected directly to my Intake manifold. I blocked off the lower CP vacuum barb. Works like a charm
I meant to take a vid last night but I was in traffic the whole night and wouldn't of been able to do a pull. I will make sure to get one today
blueLNFftw Dec 10, 2014 10:59 AM
This is what I am going to do except I am going to use the lower CP bard to a mechanical boost gauge. RPD set to AFR and mechincal boost gauge is all I really need to see.
user 72239 Dec 10, 2014 11:02 AM
Thats a good idea
I tapped my intake manifold and installed a vacuum barb for a mech. boost gauge.
blueLNFftw Dec 10, 2014 11:07 AM
Originally Posted by leemanfor (Post 7452000)
Thats a good idea
I was going to do that or go lower CP to vacuum block and then use that for anything else I may ever need.
user 72239 Dec 10, 2014 11:09 AM
I had a lot of issues with my BOV's when T'ing off the intake manifold. My Forge unit would flutter like a motherfucker until 20 psi. Sounded cool as shit but then it wouldn't close and before I swapped my maf to lower i would go into Limp mode.
blueLNFftw Dec 10, 2014 11:18 AM
That is why the vacuum block will be off of the lower CP and be a source for my boost gauge. I may try to run my BOV off it it to and see what happens.
I am buying a block off plate plate for my k04 now.
user 72239 Dec 10, 2014 11:33 AM
im wondering if you will get inaccurate readings because its not reading pressure from the intake manifold.
I know we have a TMAP in the lower CP, but we also have a normal MAP on our intake manifold to get absolute pressure inside the Intake Mani
blueLNFftw Dec 10, 2014 11:46 AM
Hmmm. Good point.
where does the line for the stock BPV come from?
