How to install the 2.8 pulley on a staged balt
How to compress the tensioner to remove the sc belt, i know some use a 15 mm but where to use it
im very confused right now thanx |
there is a tensioner
you have to place it on the lil notch and push down! be careful f done srong you can brake some shit! sorry i dont have a better pic http://img207.imageshack.us/img207/3375/434343pl4.jpg |
The way I did it, was use a pry bar. Put the one end of the pry bar under the supercharger pulley, and pry the tesnioner down. Then I took the 15mm wrench and placed it over the little hump on the right hand side of the tensioner (if you're looking at the engine straight on), removed the pry bar, and then removed the belt while holding the tensioner down with the wrench.
picture please !!!!!!!!!
Sorry, I never took a pic. I would go and take one right now, but it's dark out and raining. I'll try and take one tomorrow for you. I can tell you, this way is a lot easier than just using the 15mm wrench by itself.
i am kinda strong dont need pry bar ;)
finaly done wowo big difference it is normal that im seeing around 17.5 psi on the guage
yea that is normal some people see 18 psi ;)
| All times are GMT -4. The time now is 04:00 AM. |
