I Never Thgought I'd See This!!!!!
I Never Thgought I'd See This!!!!! With Pic of dyno
Dyno'd the cobalt last night, along with a BOAT load of other LSJ's! Nice meeting you guys that were all there.
We learned ALLOT more in the process of fine tuning these cars last night.
Now for the shocking news,
By the 4th pull on my car,
271HP and 272TQ More TQ than HP!!!! WOO HOO!!!!!!!
The car is FREAKING NUTS on accelleration! No feeling a loss of power after a shift, no feeling the powerband come on above 4500.
This thing keeps you pinned in the seat ALL THE TIME NOW!!
19psi boost, 21-23deg timing, FLAT AFR of 12.0, no kr on a mix of 93 and 110.
Dan has the same combo, except for clutch and he had an air intake, on PUMP gas, he had no KR and got 271hp and 256TQ His TQ was lower from the stock clutch slipping i'm certain!
So what we have is a redline and cobalt putting down with-in 1hp with a similar mod list!
That's awesome!!
We also got a stock redline 05, to put over 236 stock to the wheels!! We just smoothed out the AFR curve and timing curve.
Sorry to ramble but lots of exciting news
That's awesome!!
LSX RWD S/C conversion
Those are awesome numbers. What you are accomplishing with the HPTuners is great and gives everyone a base of where we can all get to with the proper tuning. Now as bad as this sounds, keep on pushing the limits because most of us also want to see what you blow up first so the weak links are exposed.
CONGRATS! I just ordered my coilovers, MSD, and big brake kit. ordering hptuners next week... hopefully we can set up a time/place so I can meet up with u and get u to fine tune my cobalt... let me know if that works or if u plan on being in Chicago anytime soon???
Was this with your new 60lb injectors and 2.5 pulley? If so, notice any belt slippage? Any boost bleeding? What was the AR between 2500rpm thru 4700rpm? I realize you said 12 but that might be an average figure, the way I see it, you will draw the most fuel just getting the blower started at those rpms.
Just curious, and good job with the numbers. Very respectable figures
I will post a pic later of the dyno chart for you, curve was perfectly flat till 6500, a little dip there.
Originally Posted by FAST06SS
NO belt slippage, boost steady and climbed about .5psi at 6500-7000rpm 19psi average
Fast06ss, Those numbers rule. Where did all this torque come from? Your set up compared to mine yielded 30 more hp and 60 more ft.lb.tq. WOW! I must have tunning! Since you know so much about this can you take a look at my dyno below? I did air/fuel when I did my runs but I can't tell what it means. Can you give me the jist if i'm lean or rich and what I should do next? You are the freaking man. Thanks.
In a nut shell, you are WAY lean in the begining, turning to way rich in the end. Flatten that out and your TQ will come up and HP slightly. I'm also running a 2.5" pulley which gets you lots of TQ
You need to see a nice flat AFR around 11.8:1
Fast do you know if this software will work on the 2.2 or is it only for the 2.0, abd how hard is it to learn/use compared to UTEC (subaru tuning software i did for my friend)
so the torque number i am flabbergasted with.. but whats with the drop off in HP? seems like everything is topping out around 270 and then only the torque numbers change.. any info on why this is occurring?
Originally Posted by eastcoastz
NICE ROB! How would the eastcoast guys go about having there cars flashed with your tune?
they would check the northeast forums for the Get robs ass here thread, and join the list
I'm still on the stock air intake and filter, stock rear manifol, all of which is very restictive at this power level on the 2.0L
It will do the 2.2 as well
A few things are happening, when you with a smaller pulley, it takes more HP from the motor to turn the SC. Eventually you hit a point wher no gain is achieved.
if i can get specs to what are currently blower is down to the nitty gritt **** nobody really cares to know, actually i might be able to get a design of what we need (if there isnt a direct swap out there)... my little sister met a guy yesterday that Designs Superchargers/Turbo systems (engineers from scratch).. ill just bribe this guy for my grace.. lol
