i think i am running rich or lean with my 3" pulley
well i took my car to the track last night and could not beat my previous time. the best i got was a 14.46 @99. i was expecting a 13 second run but dont know what happen. i can drive and my 60 foot was a 2.2. one of my friends said it may be running rich. it feels kinda of sluggish in the low rpms and doesnt accelerate as smoothly as my stock pulley. maybe the gm stage 1 reflash can fix this or it might be because of the humidity last night. if anyone can help me that would be great.
thanks Brian |
What are your pluggs gapped at?
Also, do you have a MAF-T or a reflash done? If not, that's what the problem is. You can't just change the pulley. You also need bigger fuel injectors. 42lb.ers |
Originally Posted by CTCOBALTSSS
You should be gaped at .40
Originally Posted by yellowcobaltss05
i have them gapped at .45 because thats what intense says on their website. i thought i needed to be tuned. i guess i will have to save for gm stage 1 now.
ok thanks ill try after work
Go change your gap to .040 and see if helps. I know it helped me.
well i took my car to my friends boss who owns his own auto shop and look at my spark plugs and told me i was running lean because the plugs were turning a brown color unlike the NGK's which were goldish and also he said autolites are crappy plugs and am better off with the stock plugs. hes hooking my car up to a scanner tomorrow so we can do diagnostic checks like air fuel ratio and many other important things. jw so i know, what should our afr be at to run safely?
just a note he also said that the cold air intake is probably robbing me of roughly 5 hp and he said i am better off with the stock airbox which i will put back on tomorrow. |
I have never personally heard of anyone having good experiences with Autolite's.
Did your friends boss say why he is of the opinion that the CAI is robbing power? |
thanks Brian |
Im having problems with mine. Mine shows running lean and the exhaust just doesnt sound the same anymore. i think possibly my cat is clogged. so im going to buy a downpipe. i dont know what else it could be. but there is a power loss
i put my stock plugs back in and my stock intake and it feels a bit stronger than before. still need to be tuned though
