Idle problem CURE!!!!!!!! Finally!!
I honestly doubt it. Bunch of monkey that work down there. When I told them how I fixed my problem they were like "already with only 5k miles on it????" as if this was something new to them. I would make sure to have them check into this asap to make sure.
This is not really that true.
I have a 2.2 fully bolted. I had the problem with a clean 2.2TB, a dirty 2.2TB, and a clean 2.4TB.
Mine happens the most when the car coolant is very warm.
I tuned the fans a little more aggresive and that has helped a lot, but not fixed it.
I had the same problem, and the car was throwing codes all the time... the dealer (shudder) thought it was the MAP sensor, but all I did was put in a new air filter and cleaned the throttle body, and Bingo! Problem gone.
I always assumed that this problem was because of my cams and just having a rough time tuning them. I'll try this tonight and see what it does for me.
My current fix has been to ride in 2nd gear as close to stopping w/o stalling as I could and then pressing in the clutch and jabbing the throttle while stopping before the RPM's came down to my 900rpm idle...
Well I kinda have this problem. The problem only happens when I turn on my A/C, and only when I am stopped. Like, I can drive arround w/ A/C off and never have this problem, but if I turn the A/C on and come to a redlight, or a drive through my rpms will start to bounce arround from 400-1500, and if I give it some gas it will stop, but shortly after start again. If I sit too long, if I try to pull off it will just stall, and then the car wont start up right way, I have to wait like 1-2 minutes.
Do you think this is a similar issue?
#38
alright, this thread deserves a bump.
I cleaned my TB and my idle smoothed out allot.
That thing was really oily...
before at idle i would be about 1k now its ALMOST an even 800
#40
Thanks for this man it fixed my fluttering idle especially with the a/c on god that was gettin on my nerves it would drop all the way down to 450-500 rpm when i was comin up on a stop light. Now its perfectly smooth. I did have kind of a scare though when i was takin off the throttle body it slipped out of my hand and was hanging by only the wire harness. Well after I cleaned it and installed it back in the car, i went to start it and all the car would not even try to start... I was pretty sure it had to do with the force of the throttle body pulling down on the wire harness so i went back under the hood and pushed on all the wires on the clip back in and she fired right up. Then i started driving down my driveway and my CEL comes on so I was pretty pissed about that... When I got my scan tool out there were three codes, all of which had to do with the TB so im guessin when I pushed those wires back in they set off the codes because i cleared them and they havent come back. Anyway, thanks again for the great info about cleaning the TB.
#42
i cant wait to do this tommorow on my lunch break at work. i have been pretty close to driving my car off a cliff because of that damn idle.........every freakin time i come to a stop!!! if this works i will be so f*ckin happy!
#44
#45
As long as you remove the TB and clean it, then let it dry good before re-inatalling everything you should be fine.
#46
I'm definitely doing this tomorrow.
Also, I had rough idle after I installed my CAI and discovered that it was because I pushed the filter all the way up to the MAF bung. Dropped it back down to where there's just enough for the clamp to hold on and that cured it.
#48
angel ive been having my problems with my car when i come to a stop light and stop my rpms flutter up and down so you think this will take care of all my problems?
#49
the issue with the ac being on and the rpm's bouncing all over the place, will most likely need the reflash from the dealer to fix it. I experience the same thing, and it wasn't from a dirty tb
