INTENSE Cobalt sets another record!!!!!!
#51
Originally Posted by Rogue
Well done Rob. For those interested we now stock the JBP Control Arm Bushings and you don't have to deal with customs by ordering through JBP in Canada. I think we all look forward to seeing Rob at IDD VII
Great now u tell me after I just ordered them a few days ago...I think they are sitting in customs as we speak...
#52
#54
Are you running a MBC to limit boost to 18psi or do you live in a high elevation. I thought a 2.6" pulley should make 21psi. There are a lot of poeple with 3" pulleys seeing 16psi.
#55
#56
Originally Posted by patathSS
I think it has been mentioned in other threads but no cat+Corsa exhaust =less restriction so Rob is seeing a lower PSI. I imagine it would be quite a bit higher if he had a stock exhaust system.
#61
Originally Posted by ENUFPWR
SWEET!!! IMPRESSIVE TIMES!!!!!
I see 12.99 very soon for you!!!! Congrats again
Originally Posted by max_boost
Time to order your 2.6
Way to represent Rob, nice times.
Anyways.... Congrats Rob on the new RECORD!!! 12's....WOW
#62
Yup, I was just thinking that. Does the 2.6 require grounding the snout down or would it bolt right up and replace the 2.8 Intense pully I already have?
#63
You have to grind the snout down. Or, I belive that INTENSE is suppose to be coming out with blower snouts that are already ground to fit the pullies.
#64
Thanks again guys!! There isn't a day or hour that goes by where i'm thinking of ways to go faster! You all will benefit in this mind rush! Thanks to INTENSE and the rest of the Hoosier Performance gang!!
#65
ROB (FAST06SS) GOES----12.94@106 1.82 60'
WOW....WOW...WOW.....
#70
Originally Posted by BoomInIt
Awesome finnally in the 12's. Congrats! What rpms are you launching at?
#71
Cool...Do you think we will break anything launching higher? And with this new machined snout will it fit the bigger pullies to or you have to swap the snout out for that?
#73
That is amazing dude you're making me cry with these numbers I just wish I had them lol. You should update your mods list to everything that helped you get those 12's. Good representing!
