Interceptor
Old Nov 25, 2008 | 07:00 PM
matt_jahn's Avatar
Interceptor
On my Interceptor gauge when i go to see Knock retard it just shows the previous read out. like if i was on boost and it was -20.3 it will read that. is there a setting i need to change. also the oil pressure read out reads like 65552 always? that cant be right! and i set up the shift lights to come on and i read on here i need to change my interceptor to the fastest data rate which i did. sorry so many questions i didnt find their directions that clear, and i shouldn't speak right? bad grammar!
anyone?
Old Nov 25, 2008 | 07:13 PM
DangotBoost's Avatar
Make sure you have it set on knock 3 in the set-up screen. Knock 1-2 do not work. And your oil pressure won't work without a sensor kit from aeroforce.
Old Nov 25, 2008 | 07:14 PM
matt_jahn's Avatar
ahh that would be the problem then, thanks a million. any idea on the shift lights not working
Old Nov 25, 2008 | 07:15 PM
Dead Zen's Avatar
you have to set data rate to 1. also go and set up the annuciator and set the shift lights to whatever you want. mines at 6750 for a 7k redline
Old Nov 25, 2008 | 07:59 PM
Zach06CobaltSC's Avatar
One thing that I have notice that works is if you have the 1st one set to IAT2's which could read like 60, and you have switch your 2nd one to knock it will also read 60. If you hold the button on the right down for a very short 2 seconds, like counting "one, two" and letting off, it will set it to 0.0.
But yes, have data rate on 1, and follow the rest of this thread's info.
If that was hard to explain, if your knock is reading something besides 0.0 hold down the right button for a VERY short two seconds. More like 1 actual second. But I just count "one, two" and then let go and it sets it to 0.0
Hope this helps you mate.
Old Nov 25, 2008 | 08:36 PM
HOT CARLS SS's Avatar
Where in the setup screen do you go too ajust the knock???
Old Nov 25, 2008 | 11:06 PM
matt_jahn's Avatar
k so i figured it out. i had the knock retard on 1 not three. so that reads 0.0 now. and i have the data rate on 1 and i set my rpm to 6500 but maybe i just havent taken it high enough yet
hot carls ss, go to set up and select knock 3, the other two dont work
well earlier today i didnt see any knock and i was expecting to see some. i dont have colder plugs yet and everyone says you should get them after you go stage 2. i have stage 2, ls4 tb, cai, catback, 2.9 pulley and a port/pluged supercharger. and im only seeing like 13.5 psi in top of second. i think it goes up more in 3rd though, ill check it out tom
Old Nov 25, 2008 | 11:32 PM
CobaltSS 16's Avatar
you should be boosting a lot more then that with stage 2 + 2.9
Old Nov 25, 2008 | 11:37 PM
matt_jahn's Avatar
yeah before the 2.9 i was only seeing like 12.5, which is what i was stock. i dont remember what it was at when i had just stage to. but i think the exhaust is what made it drop
Old Nov 25, 2008 | 11:43 PM
What's your redline set at? Make sure its 7000, not 6500. If it is, they forgot to flash you with the stage 2 tune.
Old Nov 26, 2008 | 12:15 AM
matt_jahn's Avatar
no its 7 grand. i just always shift right when it hits the red line on the tach when im gettin on it. i never push it up to 7, just 6500 but if the light will come on at 6500 ill be shifting just about at 7 probably
Supercharged06SS
Oct 5, 2015 09:13 PM
nathan112i
Sep 30, 2015 07:12 PM
bustaSS
Sep 3, 2015 09:33 PM
