Japeatr's knocking at the track rebuild thread
Old 07-24-2014, 07:36 PM
  #101
armcclure's Avatar
you sure thats the 256 you have? thats even better than the one zzp sells. pretty much a zzp 259 with a 56mm comp.
Old 07-24-2014, 08:06 PM
  #102
South Central *********
JapEatr's Avatar
Yup it originally came off a 6.8L John Deere before exhaust housing redo
Old 09-11-2014, 03:14 PM
  #103
JapEatr's Avatar
time for another update:
Japeatr and Hockeyman blocks are at Belvedere's for the treatment
so here is the updated build specs:
Girdled Gen 1 block with John Walters Custom spun ductile moly sleeves
Recoated Diamond 9.5:1 pistons
Pauter Rods
Oversized Titan wrist pins
Total Seal AP Stainless Rings with Napier cut second
Drilled oil passages for mains
Clevite H Rods bearings
GM Main Bearings
All new Main studs
Lightened crank
Balanced rotating assembly
ARP Head studs
Deleted Balance shafts
Timing Bolts enlarged to M8 with ARP bolts
Block bed plate tapped for 1/2"NPT and -10 oil return
LE5 TB and harness (IN HAND)
OTTP Stage 4 cams and adjustable cam gears (IN HAND)
electric water pump setup in the works, plan to wire the pump with ground switched relay
Modified tstat housing
custom auxillary oil cooler (IN HAND)
S256 with Stainless .70 AR housing and ARMperformance ported compressor housing (IN HAND)
Tial waste gate with dump
Tial BOV
zzp turbo manifold
saab custom intake manifold (IN HAND)
custom charge pipes
intercooler
OTTP Alternator Pulley (IN HAND)
Current/Future fuel system:
Powell Race Shop Custom surge tank and Bosch 044 inline pump
Deatcherks D300 intank pump
need to get some 160# injectors
OTTP RSFS with Fuellab
still running my nitrous setup but will be wiring up a timing retard relay
while it is down i will also be reqiring my wideband to a relay for the AC pressure switch (Standard HPT)
Old 09-11-2014, 03:34 PM
  #104
JapEatr's Avatar
File Type: jpg
Old 09-11-2014, 03:39 PM
  #105
JapEatr's Avatar
Old 09-11-2014, 03:40 PM
  #106
Hockeyman's Avatar
can't wait!
Old 09-11-2014, 03:45 PM
  #107
mrbelvedere's Avatar
I hope your not going to put those fittings where you pictured them
Old 09-11-2014, 03:46 PM
  #108
JapEatr's Avatar
thats the plan
Old 09-11-2014, 03:48 PM
  #109
JapEatr's Avatar
ill take a pic of my oil cooler that it is routed to
Old 09-11-2014, 03:57 PM
  #110
JapEatr's Avatar
heres the aux oil cooler (its came off David's car)
Old 09-11-2014, 04:15 PM
  #111
JapEatr's Avatar
Old 09-11-2014, 05:44 PM
  #112
InfraRedline's Avatar
Now that's an update!
Old 09-11-2014, 05:48 PM
  #113
574
574's Avatar
Whats your end power goal? Trans plans?
Old 09-11-2014, 06:05 PM
  #114
taintedred07's Avatar
Think he's going with a 4.45, not sure about hockeyman.
Nice update!
Old 09-11-2014, 06:29 PM
  #115
Spawne32's Avatar
who did the work on those LK9 manifolds?
Old 09-11-2014, 06:34 PM
  #116
TStone's Avatar
The one and only........
Old 09-11-2014, 06:46 PM
  #117
your fixing to have a real bad screw up jap don't weld those there
Old 09-11-2014, 06:53 PM
  #118
TStone's Avatar
Coolant and oil mixed is good
Old 09-11-2014, 06:56 PM
  #119
Got Bewst?
Bluelightning's Avatar
That's where ZZP mounts them
Old 09-11-2014, 09:28 PM
  #120
Spawne32's Avatar
ARM? he might not be able to port a supercharger worth a **** but ill give him props on his tig welding, looks good. Ive been looking at doing the full saab turbo swap for my car using one of the high pressure turbo's.
elaborate please for future reference lol
Old 09-11-2014, 09:30 PM
  #121
TStone's Avatar
Originally Posted by Spawne32
ARM? he might not be able to port a supercharger worth a **** bl
explain?
Old 09-11-2014, 09:39 PM
  #122
Spawne32's Avatar
explain?
rather not rehash the christmas tree port joke again lol if you wanna discuss it you can just pm me
Old 09-11-2014, 09:46 PM
  #123
Omiotek's Avatar
yeah definately dont put those fittings there........
Old 09-11-2014, 11:10 PM
  #124
armcclure's Avatar
That port style has been proven over and over again by multiple people and companies. The port I do is a combination of proven styles that I refined. Every blower I do is done on a cnc jig and is identical to the next one. I have dyno graphs, hpt logs, any many extremely pleased customers proving my work. You, on the other hand, have nothing more than an ignorant opinion. If you didn't want to "get into it" you would have kept your mouth shut.
When you have data to back up the armchair physics you so proudly slosh around the forums, try again. Until then, screw off. Maybe with your **** holster zipped you'll learn a thing or two.
Old 09-12-2014, 12:12 AM
  #125
JapEatr's Avatar
Lets discuss the oil cooler, i dont see the problem?
Quick Reply: Japeatr's knocking at the track rebuild thread
