Just bought a GM Stage 2
I found it on ebay for $310!!!! New hub w/bolts, New Belt, pulley has 2 scratches, 42# injectors and harness has 800 miles on it. How much would a dealer Flash cost me?
and on top of that wouldnt the warrenty be no good since the kit was purchased from a dealership. Thats what i was told. And if its true then whats the sence of going with the gm stage 2 kit...might as well make your own.
I was going to do this but i found out that you can't get flashed from the dealer no matter what unless you buy the kit. Just get a tune from OTTP. He sent me a gm stage 2 tune.
where do i get that and whats the differance? and what about this guys?
http://www.zzperformance.com/cobalt_...=755&catid=144
would this be a good choice?
So how would i go about getting a tune from them do i just tell them my situation and tell them all my mods? and what i want? or should i get some cooling mods and a 2.9 pulley then get a tune?
They will not give you a tune just for fun....
When you buy the stage kit, it comes with a code that the dealer uses to authenticate the GM flash...
once the code is used, it CANNOT be used again...
they cannot just give you a tune, or a code... They can only give you one if you give them the code..
Looks like your going to have to spend about 100-150 on getting a HPtune.
Your car will NOT run correctly with larger injectors and no tune.
I was talking about a tune from ZZP. Because im not sure if i have to email them or call them or something along those lines?
When u buy online, all the options are right there... You basically just give them a mod list...
OTT does the same thing as well..
You have the choice of sending in your PCM, or having them send you one... Its MUCH LESS of a hassel just to send them your PCM and have them send it back.
