Keep blowing exhaust fuse
Here's the story:
Yesterday morning I went to the exhaust shop and had my resonator cut out and shortly after leaving I blew my exhaust fuse.
Didn't worry too much because it worked fine for a few hours....4 fuses later (even higher amperage ones) it will now pop a fuse pretty much any time I go over 3k.
Once the fuse pops the cruise doesn't work and the gears I shift into seem to take a while to actually engage. Everything is fine when the fuse is good. I checked every other fuse and they're all fine too.
I don't know how the resonator delete did this but someone please help
Check you o2 sensor wiring. Make sure its tucked in the exhaust shield. There's a lip for it to sit on. It may have chaffed together to cause the short. I know my 1st o2 sensor caused this for me.
This is exactly what I was thinking. Its about the onky thing that would have been touched
I appreciate it! I'll get under and check out all the wires and everything
Here's the story:
that is the exhaust emissions fuse.!
It connects to your O2 sensors your map sensor and the evap purge solenoid.
it is most likely grounding out somewhere in the wiring.
