Losing all boost at 5k
Old 07-22-2018, 02:18 AM
07lsjsc's Avatar
Just recently changed out my supercharger on my 2007 cobalt ss lsj now I'm loosing all boost at 5k but the boost gauge continues to go up it falls on its face when I 5k any suggestions on what may be wrong??
I have ZZP stage 3 kit with the 2.8 pulley also have zzp header and down pipe with a DNA catback
Old 07-22-2018, 06:55 AM
LSX RWD S/C conversion
victory_red_SS's Avatar
My first suggestion would be checking your supercharger bypass valve actuator boost controller.
Old 07-23-2018, 08:38 AM
jdbaugh1's Avatar
Do you build full boost up to 5k?
Old 07-23-2018, 08:49 AM
07lsjsc's Avatar
yes I am
Old 07-23-2018, 09:01 AM
jdbaugh1's Avatar
You have any check engine lights? I would guess that since everything is normal until 5k then it suddenly drops that your ECU is pulling boost or throttle for some reason either something wrong with a sensor or it is seeing something it doesn't like.
Old 07-23-2018, 09:30 AM
07lsjsc's Avatar
Just checked my engine lights and I had a random misfire and a lean code but it has had it for almost a year
Old 07-23-2018, 09:32 AM
jdbaugh1's Avatar
I would think a lean reading would be enough for the ECU to cut boost. It makes sense that it would anyway. You don't want to be boosting if your car is leaning out anyway.
Old 07-23-2018, 09:41 AM
07lsjsc's Avatar
How would I fix the lean issue???
Old 07-23-2018, 09:44 AM
to many misfires at load can cause it also
Old 07-23-2018, 09:49 AM
jdbaugh1's Avatar
You have to figure out if you are getting more air than the computer is detecting, which would most likely be MAF sensor reading maybe MAP. Or alternatively if less fuel is being delivered than commanded like from low fuel pressure or clogged fuel filter.
But before we get too involved in diagnosing mechanical problems tell us about your tune. You dropped to a 2.8 pulley, did you have your tune adjusted to compensate? If you had a "bad" supercharger before you might be moving more air than you were before which can cause a lean condition if your tune wasn't adjusted.
Old 07-23-2018, 09:53 AM
07lsjsc's Avatar
I didnt do the stage kit the previous owner did so im.not sure on the tune I know its tuned to run only 93 and I'm on 60# injectors I'm going today to get my tune looked at also my whistle noise coming out of my exhaust
Old 07-23-2018, 09:58 AM
jdbaugh1's Avatar
Looking at the tune is a good place to start. Hard to say what the whistling noise could be.
Old 07-23-2018, 10:00 AM
07lsjsc's Avatar
Yea it's very hard to tell it sounds like a have a turbo in my exhaust 😂
b1gbeast
08-26-2017 11:41 PM
DEZZIE41
12-04-2010 12:27 AM
david'ss
02-06-2008 09:13 PM
2 far gone
03-06-2006 11:21 AM
06black
01-29-2006 05:34 PM
Quick Reply: Losing all boost at 5k
