LSJ bypass valve actuator upgrade
My twincharger setup blew out my LSJ bypass valve (it leaks through). I have a couple ideas that might work not sure if they've been tried.
1) Put a literal pneumatic air pressure regulator inline to limit the pressure on the diaphram
2) Modify an aluminum wastegate actuator (drill for second port, custom mount, modified shaft)
