Hey guys, had a few quick questions regarding the LSJ cooling system. I ran over a dead deer last Sunday and it did a number on my cooling. Need to replace the heat exchange, radiator, inter cooler, and condenser. After stripping the front end, I found what looks like a snapped wire over the AC compressor. I was wondering if anyone knew what it was and if it looks replaceable. My second question is which is the condenser and which is the r in the picture below, and if anyone has any part numbers/sources to buy them.
Thanks a ton
Jack
Broken plug above compressor which is the front unit, which one is the back
The one in front is the intercooler and the one in back is the radiator. The plug I don't have the answer for and no time to look through my GM manual as I am leaving to catch a plane.
I think I already took out the radiator, it's the bigger unit that the fan is mounted to right??
Thanks for all of the help guys, appreciate it. Last question I have (for now), but in order to get this cooling system up and running again, do i need to replace the condenser/that one pressure switch i mentioned above? Or can I just run the car without A/C for the time being? I dont want to replace the condenser or the switch because I dont have the needed equipment to safely and properly discharge the refrigerant.
If the condenser is ruined there is nothing to discharge. I don't see any issues running without an ac compressor other than potentially some difficulty with defrosting the windshield.
I thought I read somewhere I can burn up the compressor without refrigerant... I guess in the same vane, can I still run my heat then?
unplug the broken piece from that sensor connector, cover the connector so water cant get into it, and the compressor will not turn on even if you go to defrost, recirc, or turn on the ac switch.
Correct, the compressor won't engage if the pressure in the system is too low.
