Originally Posted by selfinfliction
(Post 5941250)
yet another that ignores the point... or can't figure it out
rules don't allow for turbos, they actually specify a single type of blower and nothing else is allowed. once they get with the times and allow turbos, you'll see every record broken in every category; bam selfinfliction... listen if you don't like it... just leave.. There isn't a reason for you to be in here. Please do the right thing and leave |
Haterz gonna ______. Maybe he thinks he's actually accomplishing something?
Originally Posted by 100% METH
(Post 5941262)
The video euthanasia posted of the vortech powered car was against a stang with twin turbos
selfinfliction... listen if you don't like it... just leave.. There isn't a reason for you to be in here. Please do the right thing and leave GTFO |
Originally Posted by Tennpenn83
(Post 5941424)
Agreed, there has been no contribution to this thread. He is only trying to start a fight.
GTFO |
even on a top fuel car if the turbo were allowed.. and created more peak hp.. it would not have the same response.. and when ur talking about a 4 second pass.. no time for error or delay
Originally Posted by 06_SIC_SS
(Post 5941730)
first off... great job, even if it doesent have great results (which i doubt) its nice to see people still trying to innovate new ways to go fast on this platform.... and turbo cars would fail hard as top fuel dragsters...... you know the size of the turbo you would need to produce 7000+ hp??? you will never rev the motor high enough to be at full boost!!
Originally Posted by Finklestine
(Post 5941800)
Not to be argumentative, but if there were turbos on those beasts they would have them spooled before launch and not stop boosting until the run was over, it's not like driving with turns where you come on and off boost...
Any ways heres what the guts of a 1600ax looks like folks. http://i164.photobucket.com/albums/u...600AX001-3.jpg http://i164.photobucket.com/albums/u...600AX002-3.jpg http://i164.photobucket.com/albums/u...600AX003-2.jpg http://i164.photobucket.com/albums/u...600AX005-1.jpg http://i164.photobucket.com/albums/u...m1600AX006.jpg http://i164.photobucket.com/albums/u...m1600AX007.jpg http://i164.photobucket.com/albums/u...600AX001-1.jpg |
So that's what the inside of a turbo looks like, who would have known
Originally Posted by euthanasia
(Post 5941940)
Top fuel cars don't have torque converters. So how would they bring the rpm's up to spool the turob/s ? Large pizza to go please lol
(Post 5941940)
They use a stack of friction disk clutches that fuse together as the car goes down the track. They dont even shift gears any more. Just launch it and as the disks fuse together it acts kind of like a cvt. And then at the end of the run they have to pull a hunk of molten slag out that used to be the disks.
(Post 5941940)
Any ways heres what the guts of a 1600ax looks like folks. [IMG]http://i164.photobucket.com/albums/u2/euthanasia662/Lysholm1600AX001-3.jpg[/I MG] [IMG]http://i164.photobucket.com/albums/u2/euthanasia662/Lysholm1600AX002-3.jpg[/I MG] [IMG]http://i164.photobucket.com/albums/u2/euthanasia662/Lysholm1600AX003-2.jpg[/I G] [IMG]http://i164.photobucket.com/albums/u2/euthanasia662/Lysholm1600AX005-1.jpg[/IM G] [IMG]http://i164.photobucket.com/albums/u2/euthanasia662/Lysholm1600AX006.jpg[/IMG ] [IMG]http://i164.photobucket.com/albums/u2/euthanasia662/Lysholm1600AX007.jpg[/IM G] [IMG]http://i164.photobucket.com/albums/u2/euthanasia662/Lysholm1600AX001-1.jpg[/I MG] oooo, blower porn! :lol: looks like 180* twist on the screws, and they look so short! haha oh and thats a FAT 3 lobe haha |
(Post 5941940)
(Post 5942032)
Air-bypass anti-lag system should do the trick just fine, but if they do get as hot as leafy says then that could be an issue even with inconel parts. The debris is probably the biggest issue though. I didn't know they were converter-less, what do they use?
it depends on what jet engine you are referring to and for the most part they are mainly worried about egt not can temps the other main reason you wont see a turbo on a top fule car is the blower is way more adaptable to to the conditions and the instant on power it delivers
(Post 5942283)
beat me to it :) but the heat is not an issue, they could use the ceramics and coating process that is used on jet turbines, that car wouldn't see a fraction of the temps those things do
soooo thats some nice looking internals;)
the exhaust is 2000 F. at a velocity of over 2,400 feet per second and they did open it back up to a full 1/4
Yes and back to the topic of the twin charge. If done right with this blow it would be amazing. You see, this blower flows an ass ton of air, but it starts to struggle at high pressure ratios. So if we can keep the pressure ratio somewhat sane with a huge pulley, like under 2 and put a very large turbo on it, lets say limited to 10 psi. So when you first start you have some killer torque and airflow from the blower (and a maximum manifold boost of 15psi), this helps spool the turbo way sooner than it would otherwise. Now the turbo is spooled up and putting out 10 psi at the inlet to the blower, the blower will then be putting 35 psi into the intake manifold, but it will still be at a pressure ratio of 2 so it will be still very efficent. What you get is a metric ass ton of peak power but a broad torque curve.
You dont get this with the mp62 because it doesnt flow enough air to be worth it, this would also be amazing with the M90 blower. I think though that with the M90 and the AX1600 you would need a under drive crank pulley to get the pressure ratio low enough.
Originally Posted by mrbelvedere
(Post 5942385)
i really dont see any blower other than the m62 being efficient for a twin charge...and i dont even think anyone still runs a twin charge setup, they wised up and went straight turbo
(Post 5940979)
welp if thats how ur gonna argue.. top fuel cars run blower.. bam..end of story
Originally Posted by RonSS
(Post 5942493)
Turbo Chargers are illegal in Top Fuel.
I'm happy to see that you guys are making this work.
Please give me a reason to supercharge my black phantom again. |
Originally Posted by Deathscythe
(Post 5942582)
