M62 spacer plate- zzp
LSJ M62 Spacer Plate
Was wondering if this really did anything besides add the meth port without tapping into the IM. It says it helps increase air flow, but has it been proven? I am just curious before I drop the money on it. I do plan on running meth at some point, but not just yet. I am running a 2.7, 60s, option b, dual pass, phenolic spacer, and mid length header/catted dp, ls4, and k&n. Want to up to a 3in intake, ported blower, meth, 2.6, and maybe port the ls4 (see if I can get any gains from that, although doubtful with the m62), and a stealth/griffin h/e. |
Save your money if you're looking for performance gains out of it. If you spray meth I recommend getting a throttle body spacer and spraying it through the blower. Far more benificial.
alright, I appreciate it.
phenolic spacer is junk also
Originally Posted by mrbelvedere
(Post 7567709)
I had ran this at one point for a nitrous tap
So basically all it is good for is a tap. Cool. I know not to waste the money now.
Thanks guys |
