M90 Swap Revisited
Old Aug 8, 2007 | 12:34 PM
Asphalt Assault's Avatar
Originally Posted by Onyxd04Redline
I think the stocker is a 3.8" and will work my way down from there. I'd really love for this swap to yield like 260-270whp and still have room to max out the blower.
(7000RPM*6.25" crank pulley)/3.8" SC pulley = SC RPM of approx 11,500
just FYI. what the rotors are turning I can only presume to be the same as the SC input shaft. Dont know if it is under or over driven internally.
Old Aug 8, 2007 | 01:56 PM
Jmc007's Avatar
It could fit if you're ready to get a huge hole in your hood LOL.
http://www.magnusonproducts.com/mp90.htm
Old Aug 8, 2007 | 02:04 PM
ItalianJoe1's Avatar
Its only 5.5 inches tall, and it sits on our manifold at an angle. How much bigger is it? I have seen them in person and they don't seem a LOT larger, just wondering. I don't have time to look it up right now and I'm sure someone else already has.
Old Aug 8, 2007 | 05:59 PM
Onyxd04Redline's Avatar
Why does everyone say it won't fit under the stock hood?
M62 Height = 4.91
M90 Height = 5.30
Old Aug 8, 2007 | 06:06 PM
elecblue06's Avatar
M62 Height = 4.91
M90 Height = 5.30
have you been under your hood with it closed? how do you know the m62 has that much clearance haha
Old Aug 8, 2007 | 06:08 PM
Does the ion have more underhood room then the SS?
Old Aug 8, 2007 | 06:19 PM
Cobalt_SSTuner's Avatar
I say the hell with the haters and give it a shot. Its ur car do what you want.
Old Aug 8, 2007 | 06:29 PM
bl0wnbalt's Avatar
this should be pretty cool if you go through with it, im not a fan of any of the s/c swaps, due to a big waste of money for minimal gains, but if you can do the swap for under 500 bucks, a 20hp gain would be awesome, gl man, m90 ftw
Old Aug 8, 2007 | 09:21 PM
Serpico's Avatar
Originally Posted by TVS_SS
Trust me.. M90 is not what you want.. its too big, still only rated to 14.7 psi like the M62, not very efficient..
What you want is a TVS R900 or R1050..
i talked with justin @ magnuson and as of friday they still arent available earliest he said they would be available is november....if were lucky
Old Aug 8, 2007 | 10:02 PM
ralliartist's Avatar
I seriously don't think a 20hp gain is worth it. 500-600 bucks is what it is costing you. That may cost someone else a few hundred more. I also don't think that you are going to get to 260-270whp until you are pullied down with 60lbers just like the m62. with that much more heat from a bigger blower, it won't be worth it. gl though. let us know how it goes.
Old Aug 11, 2007 | 03:47 AM
  #36
I just reviewed compressor maps. it is totally not worth it. TVS is far better. I like the TVS 900 but a 1320 could be an option.
Old Aug 11, 2007 | 04:28 AM
  #37
BACK2GM's Avatar
It would be nice if these options were available......
Old Aug 11, 2007 | 04:29 AM
  #38
r900 isnt?
Old Aug 11, 2007 | 04:31 AM
  #39
InfinityzeN's Avatar
There's where my view of it comes from ssnipes. And I think I would lean more towards the TVS 1320.
Old Aug 11, 2007 | 09:16 AM
  #40
TVS_SS's Avatar
R1050 is what you want.. 1320 would be for a very wild, huge cam, ported head, etc... car.
For a bolt on, a 900 or 1050 wll be what you want..
Old Aug 11, 2007 | 09:33 AM
  #41
Well I don't plan on doing it until my warranty expires. Then I'm going to get a bunch of head and valvetrain work done, get a slightly more aggressive cam with 0.500" of lift, forged pistons, and see what I can get out of it.
Old Aug 11, 2007 | 11:34 AM
  #42
M62 states - for 2.5L to 4.2L engine or motor that is built and suitable which can be a smaller application.
R1320 states for 2.2L so I wouldnt count it out. but I would be concerned and would want expertise to ensure it will work properly.
Old Aug 11, 2007 | 01:04 PM
  #43
are the tvs's available now?
Old Aug 12, 2007 | 07:25 AM
  #44
TVS_SS's Avatar
unfortunately no...
Old Aug 12, 2007 | 08:23 AM
  #45
Someone keeps forgetting that the price of the TV's does not make them cost effective.
Old Aug 12, 2007 | 09:08 AM
  #46
TVS_SS's Avatar
Cost effective + higher output + boosting system = 0
Old Aug 12, 2007 | 09:17 AM
  #47
Will the gains be on par with the 1.2L whipple? If so what a waste.
Old Aug 12, 2007 | 12:14 PM
  #48
shaunmcdee's Avatar
Good luck with your project, if it works i may just follow in your footsteps, i have an eaton m90 sitting here in the garage, Its out of my roomates whipple charged gtp.
Old Aug 12, 2007 | 12:24 PM
  #49
TurboTommy's Avatar
Go for it man....where did you find an m90 for that cheap?
Old Aug 13, 2007 | 12:00 AM
  #50
Cost is of no issue if it is bolt in, same cost or less than turbo, and I can obtain my HP goals.
