Make your own Option B Kit Cheaper!!!
Is there any way to make an Option B Kit cheaper than buying one from ZZP or OTTP?? I think $120 for a reservoir, hose, and a few hose clamps is ridiculous honestly....LMK if there is a way or if you have done it maybe help me out and show me how....Thanks!!
People have done it, the nice thing about ZZP and OTTP is that you can get the bracket which looks better and is nicer then trying to rig up something. I have an option b kit and brackets that I selling, less then 1k miles on it but want $105 shipped
Kdub, is there any way i can get pics of it....you can text me at 606-434-7209 as well , which would be easier, I'm about to go outside and Weed-eat for a while but will have my phone on me, Thanks!!
I have an option B tank I'd like to get rid of (it's the coolant bottle from an Ion, but same thing). PM if you're interested, and I'll get you pics.
And personally, I'm more of a fan of a flow through design that keeps fluid constantly moving through the bottle...I ended up using a coolant bottle I found in the junkyard (I think from a mx3), made brackets to mount it behind my power steering pump, then plastic welded two 3/4" barbs to it.
This is the flow through I made. Can't see the bottom barb in the pic, but its at the bottom of the tank facing forward. I used to threaded 3/4" barbs from a local boat supply shop, and plastic welded them.
What do you mean the stock filler neck?? The actual tube gets removed where you put in coolant?? So where do the line in and out of the tube go to....Do you just run the 3/4 hose from the new tank into the port where it originally runs to from the filler tube??
Smc252 (12-20-2021)
Here is a complete list of everything needed to assemble your own Option B kit, including part numbers.
1-10368831 Surge Tank
1-15075118 Surge Tank Cap
1-28412 Hose 3/4"X3'
2-28635 Connector
1-47063 Elbow
13-50012 3/4" Clamp
2-62004 1/4" Clamp
1-762000 Cross Connector
1-844240 Brass Fitting
3- H-461 1/4"X3' Hose
Google is your freind on this one. You should be able to get everything for around $65.00.
2-28635 Connector
1-47063 Elbow
13-50012 3/4" Clamp
2-62004 1/4" Clamp
Smc252 (12-20-2021)
09-28-2015 12:51 PM
