max power for sc
Old Aug 8, 2008 | 11:59 PM
twiztidcobaltss's Avatar
max power for sc
just wondering what is the max power the stock blower can handel. with smaller pullies and intake and exs. cooling mods. what kind of horsepower can one exspect. can you list mods that work.
Old Aug 9, 2008 | 12:01 AM
Perfect.disguise's Avatar
Why two threads about this?
https://www.cobaltss.net/forums/2-0l-lsj-performance-tech-47/max-power-sc-lsj-126803/
Use the search feature.You will find anything you want to know.
UmeNNis's Avatar
little over 300whp.
Old Aug 9, 2008 | 12:02 AM
i didnt think it went through
CBodnar's Avatar
well i am at 307whp and i only spent $907 bucks on my is my known to fame and over 4 bottles already used. 45wet shot + gm stage 2 + 2.8 + filter on stock intake. also 1step colder plugs. that's only on a 45wet shot w/o a bottle warmer. i assume i could get a lot more out of it
Old Aug 9, 2008 | 12:03 AM
did you do any cooling mods
Old Aug 9, 2008 | 12:07 AM
CBodnar's Avatar
big cx h/e on ebay. buy it right from cx motorsports
https://www.cobaltss.net/forums/how-guide-43/how-install-mount-big-cx-heat-exchanger-124669/ my how guide on to install for less than $199
https://www.cobaltss.net/forums/2-0l-lsj-performance-tech-47/cbodnars-307whp-nitrous-cobalt-123414/ my 307whp dyno sheets and video click it post in there tell me what u think
Old Aug 9, 2008 | 12:08 AM
what kind of mileage do you get
Old Aug 9, 2008 | 12:11 AM
CBodnar's Avatar
27+ that is city. highway would be way over 30
i've got 23k miles almost on the vehicle and it's a 2007
been running 2.8 pulley on for 20k + miles now
Old Aug 9, 2008 | 12:13 AM
now a wet shot just sprays into the intake tube right
im tired of those srt4s
Last edited by twiztidcobaltss; Aug 9, 2008 at 12:13 AM. Reason: Automerged Doublepost
Old Aug 9, 2008 | 12:14 AM
CBodnar's Avatar
sprays nitrous + fuel in together as a mix in the intake tube. i have stock intake it sprays into. when i dyno'd that day the degree's was 99 so yeah sweet numbers for a bad day.
Old Aug 9, 2008 | 12:16 AM
ur clutch slip at all
Old Aug 9, 2008 | 12:21 AM
CBodnar's Avatar
lol if your tired of them then check this out my brotha
https://www.cobaltss.net/forums/war-stories-54/ss-sc-vs-six-different-srt-4s-126755/
^there is like 6 srt-4s where only 2 beat me. one when i was stock the other one just a little edge over me. that was when i was on only gm stage 2. and my buddy had gm stage 2 and only intake. both are cars seem to run really good. mine just runs a little bit better and pulls stronger top end. check the video's out and post in that thread tell me what you think.
since then i have put a filter on the stock airbox and cut the box off so it's basically injen cai except plastic and also 2.8 pulley which gives you a sick advantage and the 45wet shot.
yeah we heated up the bottle with a torch just a little bit and i was pulling 330torque at 3.5k rpm's and it slipped. if it didn't slip god i would of went for the moon on that run.
check out the thread. watch the vid's and see the chart. read i was driving the car for 3-4 hours that day it was hot out and all odd's were against me + no bottle warmer
also bottle was cold due to running a/c on it for 3-4 hours
also this isn't a cobalt but saturn ion redline. same motor. running stock m62 supercharged and i am sure he is over 400whp.
https://www.cobaltss.net/forums/war-stories-54/16psi-c16-150shot-22%2A-timing-%3D-z06-killer-123456/
Old Aug 9, 2008 | 12:26 AM
well that makes me feel a little better. what about hp tuners programer
Old Aug 9, 2008 | 12:35 AM
Area47's Avatar
Rent me! per hour
300whp on a stock m62 without nitrous requires a lot of work and money in different places. plus it is very very touchy on that said tune file.
Old Aug 9, 2008 | 12:41 AM
so cold air intake, header and exst, nos, 2.7 pully h/e, pugs, injectors, and a tune would put me at what do you think.
Old Aug 9, 2008 | 12:43 AM
Area47's Avatar
Rent me! per hour
do you want it to live very long?
Old Aug 9, 2008 | 12:44 AM
whats wrong with it.
Old Aug 9, 2008 | 12:46 AM
Kibosh3's Avatar
so cold air intake, header and exst, nos, 2.8, meth injection , h/e, pugs, injectors, and a tune would put me at what do you think.
fixed
Old Aug 9, 2008 | 07:03 AM
CBodnar's Avatar
dude 300whp on stock m62 is easy. look at me i've already hit 300whp on stock everything. just modded the intake and put a filter on it and cut out the box. 2.8 and gm stage 2 tune. run the fuel jet rich and you will be fine. iat2's never go above 120 after a bunch of wot pulls and i am getting my aem wideband soon so i'll take pulls with it and show everyone i am sure i am running fine knowing i've sprayed so much already
Old Aug 9, 2008 | 11:13 AM
Area47's Avatar
Rent me! per hour
take the nitrous off and lets see you hit 300 without it.
not so easy is it
Old Aug 9, 2008 | 11:15 AM
lsjwannabe's Avatar
lawl yeah so easy
Old Aug 9, 2008 | 11:23 AM
CBodnar's Avatar
not so easy is it
i never said w/o nitrous. i said with nitrous it is simple. im only on a 45shot. sweetdreamz in on a 150shot and i imagine he is over 400whp
Old Aug 9, 2008 | 11:32 AM
lsjwannabe's Avatar
what happens when the bottle runs out?
Old Aug 9, 2008 | 11:39 AM
JimzSS's Avatar
here we go with my dad can beat up your dad
