Cobalt SS Network
Cobalt SS Network (https://www.cobaltss.net/forums/)
-   2.0L LSJ Performance Tech (https://www.cobaltss.net/forums/2-0l-lsj-performance-tech-47/)
-   -   Need Help (https://www.cobaltss.net/forums/2-0l-lsj-performance-tech-47/need-help-45238/)
hatrickstu Jan 27, 2007 10:37 PM
Need Help
Ok guys i know quite a few people are running aftermarket DP's in here and i recently put on my vibrant 2.5'' catless DP. I bought it used and it came with the gasket that mounts between the DP and the "catback." I noticed it looked like the gasket had been leaking on one side of it and checked out the DP to see if i could find the problem. It looked like the flange was not mounted as straight as it should be, like instead of being at a 90 degree angle angle it was like 100 degrees or so. I took this into account when mounting the pipe up on the car and held both pipes up in order to try and get the best fitment possible. I tightened the two pipes as flat together as possible and today i can see that there is a slight gap in between the flanges on the bottom. I can hear the exhaust leaking out and want to know if anyone else has this problem and what can be done about it.
http://i24.photobucket.com/albums/c3...xhaustleak.jpg
rally Jan 27, 2007 10:52 PM
Only thing I could think of is take it to an exhaust shop and have them reweld the flange.
Nice illustration by the way
RaineMan Jan 27, 2007 11:08 PM
Good advice... just take it to an exhaust shop... they'll fix ya right up.
hatrickstu Jan 27, 2007 11:37 PM
yeah that is def. a good way to do it, i need to have them put the resonator back on as well...
RaineMan Jan 27, 2007 11:42 PM
sounds like you'll kill two birds with one stone.
hatrickstu Jan 27, 2007 11:46 PM
yeah but i just hope they dont charge me too much, they should not considering i had my catback system made there.
RaineMan Jan 28, 2007 12:04 AM
to fix that? probably an hours work max...
hatrickstu Jan 28, 2007 01:23 AM
shit 10 minutes max. they do good work too.
anyone else even have this problem?
hatrickstu Jan 28, 2007 06:08 PM
anyone...
bamfnss Jan 28, 2007 06:42 PM
goto a muffler shop, or cut off the flanges yourself and put a clamp like this for your connection...
http://vertexnow.com/Verocious-Motor...-Exhaust-Clamp
Blown 4-banger Jan 28, 2007 07:50 PM
:lol: HA HA HA!!! Man you make the best exhaust diagrams!!! So realistic! :lol: :lol: :lol:
jk man
squeak Jan 28, 2007 11:46 PM
what sice 16 inch drag radials are you runnig and what brand?
hatrickstu Jan 29, 2007 12:57 AM
dude this has no bearing on the thread, pm me if you really want to know
