Need tool to pull s/c rotor bearings
Anyone know of a tool that I can use to pull the rotor bearings from my blower to replace with ceramic bearings? The ceramics will disipate heat better and are more durable, adding longevity to the blower, but only if I get them installed.
The stock bearings are fine. You should not have to replace them unless you got some **** in there and ground em up. I talked to Steigemier and they said the bearing aren't meant to be replaced.
Well maybe I'll sell/send them back. Anyone else have any input? Not dis-regarding your post Blown4-banger, just seeing if there is any other info avail.
DANRICKARD
10-01-2015 12:08 AM
