Needing help with timing chain 06 cobalt ss/sc
Old May 17, 2017 | 09:35 PM
Slowbro's Avatar
I'm needing help I'm new to the whole cobalt 2.0 lsj world and I took apart my timing chain as the balance sprocket broke but when I ordered the new balance shaft set it can with a solid sprocket instead of the original one so I'm needing help with the issues please
Old May 17, 2017 | 10:01 PM
Sharkey's Avatar
what exactly is the issue? that the new sprocket looks different than the old one?
Old May 17, 2017 | 10:14 PM
Slowbro's Avatar
Yes the original one looks like its on a bearing and moves back and forth the new one is a solid one piece sprocket
Old May 17, 2017 | 10:16 PM
Lookup the Gates timing chain youtube video (or at least I think it's Gates) they go through the entire process including torque specs
Old May 17, 2017 | 10:20 PM
Slowbro's Avatar
This is the one i need
This is the one it came with
Old May 18, 2017 | 12:17 AM
Sharkey's Avatar
looks like you got one for a 2.2/2.4l, it appears the 2.0l uses a different sprocket. you can get it from crate engine depot, its part # 12642713.
Old May 18, 2017 | 12:57 AM
Slowbro's Avatar
Thank you it's correct your awesome
