New High flow lower manifold
Old Jul 15, 2008 | 11:13 AM
  #101
Blown 4-banger's Avatar
Originally Posted by rrutter81
hit the nail on the head.
I dont feel like taking my intake manifold off every 6 months just to be slightly cooler than aluminum by a few degrees. I dont race funny cars.
Also ANOTHER good point made was the cooling system. I think some gains can be gained modifying the intake manifold how it stands, but modifying the dynamics of how the cooling system works will be MUCH greater.
Also copper vs aluminum is really a toss up. If you want to rebuild your engine every track run you build your 1500 hp ecotec. However if you are a daily driver (like me) keep the aluminum. You will see ALOT better gains through a redesign of the system than just changing the material.
my .02 cents
You know the point of this manifold is not only cooler temps, but also MUCH more efficient air flow. As it is now, the stock manifold is like a maze for the air, sharp turns and restriction all over the place. If rebel DOES come through with this manifold, I will DEFINITELY buy it. Cooling isn't even an issue, hell I'm making a 2 gallon trunk mounted resevior, switching to distilled water, and using an electric water pump from a small block chevy. Once I dump ice into the resevior, the water flowing through the cores should be in the 30's. My intake temps will be lower than ambient. However the air will still have to go through the maze known as the stock manifold.
Old Jul 15, 2008 | 11:14 AM
  #102
rrutter81's Avatar
then in essence you agree with me that a redesign is better than material
Old Jul 15, 2008 | 11:30 AM
  #103
freakta's Avatar
so is this thing for real. i was just readin an older post where they just modified the old intake manifold now it looks like its a totally diff peice that they will make on there own. so wich is it. and the new design looks alot less expensive than the old one.
Old Jul 15, 2008 | 11:31 AM
  #104
Omega_5's Avatar
The old price was for a ported manifold PLUS a ported charger.
This price is for a whole new manifold... with no ported SC.
Old Jul 15, 2008 | 11:33 AM
  #105
Speedytec's Avatar
Originally Posted by Werewolf SS
Well according to PSE as stated in the orginal thread the psi on a stock pulley is around 18 psi before it hits the manifold and after due to the bottelneck comes out at 12.5psi roughly. Thats a 5.5 psi loss between s/c and post manifold. They state the back pressure of this makes the air go back into the s/c housing. Air which is already hot and the cycle creates the heaton effect we all know and love
So I was wondering if this manifold is going to flow better we should get higher boost therotecily.
Could imagine that the stock manifold was restrictive at higher CFM's, but 18PSI on the blower in stock form is already quite bad for the M62. Was looking to the compressor map and wondering what effect less restiction (so a smaller pressure ratio) would have:
What cfm (roughly) runs through an LSJ at ~6500rpm with 12 psi (0.85bar) boost pressure? Should be around 615m3/hr, right? (2 ltr / 2 x 6500 x 60 x 1.85 x ~85%VE??)
So in a non-restrictive intercooler world we are in the graph already at the crossing of 615m3/h and ~1.85 P-ratio [(12.5 + 14.7)/14.7]...
Standard LSJ intercooler=> same cfm at 18 Psi (1.22bar) "blower pressure" => Out of the graph...
And you can fill in the blanks with a <2.8 pulley...
Very very interrested in the practical outcome of these new manifold designs.
Note: Looking to this grapf I realize again that this blower is pretty inefficient at higher rpms / cfm's...
Old Jul 15, 2008 | 12:06 PM
  #106
rrutter81's Avatar
lol where were you last week?
anyway, if rebel allows for the option of aluminum im in. Also a CAD drawing would help.
was just checking what you put in,
The m62 displaces 1 ltr
m62 doesnt max it's rpm at 6500, the lsj does.
Sorry been doing a zillion things at work
bump for being wrong (screenshot it)
Old Jul 15, 2008 | 12:38 PM
  #107
lewisb13's Avatar
From: Home: Utica, MI Current Location: Mobile, Alabama
Look at you guys stealing pics outta MY gallery!!!
Old Jul 15, 2008 | 12:46 PM
  #108
rrutter81's Avatar
you pointed me to it in the beginning....
btw (strictly) the m62 = 814.8 m3/hr
Rather keep the SC talk in the SC thread and keep the intercooler info here
  #109
lewisb13's Avatar
I know Im just messin with ya~!
What speed is that at?
Old Jul 15, 2008 | 12:52 PM
  #110
Omega_5's Avatar
Stock pulley, 7000RPM
(actual... not chart based)
Old Jul 15, 2008 | 01:02 PM
  #111
rrutter81's Avatar
13,500 rpm
Originally Posted by Omega_5
Stock pulley, 6500RPM
i wouldnt be that cheap, i knew what u were saying
Old Jul 15, 2008 | 01:04 PM
  #112
Omega_5's Avatar
Actually... that is wrong... 7000RPM... I read the wrong line on my paper here.
(Notice the edit)
And it's not quite 814... that would be ~800.
Old Jul 15, 2008 | 01:07 PM
  #113
rrutter81's Avatar
(Notice the edit)
The CFM will change depending on pulley size anyway and alot of other things. I dont have a chart to measure rpm of engine vs the rpm of the heaton.
Old Jul 15, 2008 | 01:12 PM
  #114
Speedytec's Avatar
The lsj displaces 4.ish liters if im not mistaken (i didnt google sue me)
I sometimes do have to work a bit for my euro's over here also...
Was just roughly looking to the engine's max cfm need:
LSJ displacement: 2.0ltr.. (duhh), but 4 stroke, so 2 revolutions for 2 liters of air sucked in.
Say max rpm =6500/min
Say VE = ~85%?
Therefore an "NA" LSJ would do: 2.0 / 2 x 6500 x 85% x 60 min/hr / 1000 l/m3 = 332 m3/h. But at 12 psi boost there is 1.85 x 332 = 613 m3/h pushed through the head.. [pressure ratio = (12 + 14.7)/ 14.7 = 1.85]
And this same CFM of 613 m3/h should be shoveled in by our M62 blower, right?
(All calculations rough ballpark figures!! There's a lot more to it, but this is just to see where we are in the M62 graph. )
Actually we can draw a line from zero (0 rpm, 0 cfm) to this max CFM/ PR point. But in the real world with resistances (IC!!), the pressure ratio will rise not linear with increasing cfm. Therefore this line will look like an exponential curve upwards...
But there is no doubt that less resistance with equal cooling capacity only can improve our situation.
And some nice runners... (Even better with hotter cams where pressure waves tend to do bad things with idling.)
Old Jul 15, 2008 | 01:13 PM
  #115
Omega_5's Avatar
How about one to measure typical pulley sizes vs engine RPM, showing SC RPM (regardless of what SC your using)... to find theoretical volume flow, just multiply by your Vol/rev.
Old Jul 15, 2008 | 01:14 PM
  #116
rrutter81's Avatar
(Notice the edit)
I think dealing with the actual number of the 7000 RPM engine will not equal 13,500 RPM heaton. It will be off enough to validate the 800ish.
Also im SC'd out to piddle over such small differences. We can raise the dead no the old thread if we need to.
Right now id like to keep to the intercooler topic if we can
Old Jul 15, 2008 | 01:15 PM
  #117
Omega_5's Avatar
Indeed.
Old Jul 15, 2008 | 01:16 PM
  #118
rrutter81's Avatar
Say VE = ~85%?
your looking at the volumetric airflow of the engine.... not the heaton
n/m
reading>me
I see where your going ( i think ).
Indeed.
btw good post with the chart
Old Jul 15, 2008 | 01:21 PM
  #119
Speedytec's Avatar
(Notice the edit)
I'm running a bit behind here.....
Is this actual CFM of the M62 measured on a real engine load (so with boost pressure), or on some test stand measuring pure cfm?
(Things are getting complicated quickly here... Better stay to thread: A better inlet manifold! But I saved the rpm chart. )
Old Jul 15, 2008 | 01:23 PM
  #120
Omega_5's Avatar
Is this actual CFM of the M62 measured on a real engine, or on some a test stand?
(Things are getting complicated quickly here... Better stay to thread: A better inlet manifold!)
Well... the 'actual' isn't really the actual. It's just factoring a few volumetric losses.
I'd like to see an actual SC 'flow dyno' done on the M62 to get some solid numbers.
Old Jul 15, 2008 | 01:29 PM
  #121
rrutter81's Avatar
ask and ye shall receive
for those wondering how to read this
I think that the Pressure ratio should be calculated a bit different:
Ratio of 1.0 means zero compression, 2.0 the doubled compression of the inlet air.
So in psi (bar's are a bit easier, as that is boost + 1):
Inlet ~14.7 Psi absolute
SC outlet say 15 Psi boost => 12 + 14.7 = 29.7 Psi absolute pressure
Pressure ratio : 29.7/14.7 = ~ 2.0
1 CFM = 0.028 m3/min
or
1.68 m3/hr
The green lines are the rpm of the heaton
1.81 PR = 14.7+12(absolute PSI) / (14.7)
13500 is the estimated max 1.8ish pressure ratio looks to be 760 m3/hr
1/.028 = 35.714285714285714285714285714286
35.714285714285714285714285714286 (CFM) * (760 (m3/hr) / 60 minutes) = 452.38095238095238095238095238088 CFM
Old Jul 15, 2008 | 01:34 PM
  #122
Omega_5's Avatar
Isn't that the theoretical chart?
I'm looking for one from a certain company who has an SC flow dyno... (ahem... ZZP...)
Old Jul 15, 2008 | 01:36 PM
  #123
black06ss's Avatar
good i dea but im still out 1500 bones from the twin screw stuff. others can waste their 100 bucks on this.
Old Jul 15, 2008 | 01:39 PM
  #124
rrutter81's Avatar
i thought it was an actual dyno from eaton engineering.
Old Jul 15, 2008 | 01:40 PM
  #125
ralliartist's Avatar
and here's why I said I'm holding my 100 bucks. There were a few people that got totally screwed by RAW.
