| Taylor Makris |
Jan 28, 2025 12:51 PM |
New LSJ Cobalt owner, few issues
Hey guys new owner here! So i picked up a lsj cobalt but it was only making 3 lbs of boost. Supercharger and engine sounded fine so i bought it anyways figuring it would be an easy fix. Drove home 8 hours fine. Went to Oreillys when i got home and grabbed some vacuum caps and clamps. I unplugged the bottom line from the bypass valve on top of the supercharger that goes to that little electronic deal and capped that and left the hose to atmosphere. Gave it a drive at it makes 12-13lbs now and is a little screamer! Is this the bypass valve that needs replaced? It looks new. The arm seems to move freely by hand. Or is it the little electronic deal? If it is what the hell is it called, what does it do, and what is the part number haha. Also it has code P 0171 and P 1133. I believe for lean bank 1 and 02 sensor fault? He said the car has full exhaust long tubes back. He said he replaced the 02's. I haven't lifted it up yet to look it over with a fine tooth comb. It also has a zzp intake. Other than that i believe stock. Is this from the intake and exhaust without having a tune? Car seems to drive really well for its age. Any help would be appreciated and thank you guys!!
