New to modifying cobalts need advice on a good setup thanks!!
Hi. I just registered here and im new to modifying cobalts. Mines just a stock 06 SS for now. :cool: But i had a whole list of performance stuff and upgrades and i just wanted some advice from people who have done this stuff to their cars and had good results. So far my list includes:
Full Hahn Racecraft Exaust Kit+header and downpipe k&n cold air new intercooler(need lots of help with this) 2.8 pulley 60 lbs injectors decent tune(dont know how to tune myself or where to get a good tune around here) advice on a new clutch (want better clutch just dont know a good type and i was looking for some higher performance camshafts but havent been able to find any from what ive seen all you can do is get a stock regrind :thumbsdow also i heard that the halo led lights suck majorly i really like them and was wondering if there are anyways to modify them to make them work like they are supposed to or if there are better versions of them. also i was looking for some good led taillights if anyone knows where to find some good ones throw that out there thanks! again any advice is open just wondering if this is a good setup its just a daily driver that i want to make a little more beefy and make it mine alos i was wondering what kind of power i would be looking at and what other parts i should get for it or certain mods i should consider thanks again |
https://www.cobaltss.net/forums/2-0l...-guide-217195/
Read that. Your setup sounds nice. ZZP's stage 3 heat exchanger is your best bet for a front mount. Trifecta also offers great mail order tunes. You should think about going with a 2.7" pulley and tossing some meth on your setup. Meth is fun. Or go big and get 80# injectors and run e85 |
Originally Posted by dman1320
(Post 5283845)
Full Hahn Racecraft Exaust Kit+header and downpipe k&n cold air new intercooler(need lots of help with this) 2.8 pulley 60 lbs injectors decent tune(dont know how to tune myself or where to get a good tune around here) advice on a new clutch (want better clutch just dont know a good type and i was looking for some higher performance camshafts but havent been able to find any from what ive seen all you can do is get a stock regrind :thumbsdow again any advice is open just wondering if this is a good setup its just a daily driver that i want to make a little more beefy and make it mine alos i was wondering what kind of power i would be looking at and what other parts i should get for it or certain mods i should consider thanks again |
I have the ZZP Stage 3 H/E and to be honest I would not get it again. It bolts up nicely with no problem and fills the entire front hole, but the fins are always bent when you get it. In my opinion that looks like shit. If I were to buy a new H/E I would get OTTP's. Doesnt fill in the entire grill as nice but overall its a much nicer quality H/E and still bolts directly up.
If your looking for a canned tune I would look into OTTP Stage 2 kit. Its about a 40 horse increase depending on your supporting mods. But if your looking to do a custom tune look into buying a HP Tuner or finding someone who has one that is willing to tune you. Then piece the rest of the kit together. This would be much cheaper and better than buying a kit with a canned tune (just my opinion). For an intake look into OTTP's 3inch or ZZP's 3 inch. ZZP's 3 inch intake wont work on 2007 and up I believe. Rubs against the brake lines. As far as cams. Stock ones are suffiecent enough. Put your money else where. Spec 3+ is a good clutch. I would also look into meth. Not needed for that kind of set-up but def helpful. Just my 2 cents :-) |
Originally Posted by ssblackstealth
(Post 5283879)
if you want good power gains and daily drivablity i would go with the zzp stage 3 kit, it has the 60s, 2.8, and a heatexchanger (intercooler), oversized tensioner pully, and a can tune for a great price! as far as intake, id go with a 3in like fujita, zzp, or ottp; the k&n is ok but its a small diameter... after you should get a trifecta tune!! you dont need any cams, its too much work for not much gain on our cars, dont waste your money. spec 3+ is a great clutch for your application.
2.7 pulley or 2.8 not sure yet zzp cai zzp stage 3 h/e 60 lbs/h injectors and harness spec stage 3 clutch hahn full exaust w/ dp and headers also wondering if i could find all this stuff in a kit without the pcm theres a guy around st.louis that does trifecta tunes should i get all my parts on and installed first then go get the tune from him? it was on their website as a tuner in this area also still wondering about the halo projector lights are there better versions or ways to make them better than stock lights and i was looking for some good led tail lights thanks |
go tvs
Check out thee classifieds for the parts. If you don't need a PCM. And possibly eBay for the lights.
my lenses on my ebay halo lights look like crap after 2 years but the oem ones still looked fine. I personally would go with oem retrofit. there is also the griffin heat exchanger that mounts in the stock location but it is expensive.
(Post 5284424)
so i finally narrowed down my performance stuff to this:
2.7 pulley or 2.8 not sure yet zzp cai zzp stage 3 h/e 60 lbs/h injectors and harness spec stage 3 clutch hahn full exaust w/ dp and headers also wondering if i could find all this stuff in a kit without the pcm theres a guy around st.louis that does trifecta tunes should i get all my parts on and installed first then go get the tune from him? it was on their website as a tuner in this area also still wondering about the halo projector lights are there better versions or ways to make them better than stock lights and i was looking for some good led tail lights thanks all of it usually comes with the pcm but you could prolly call zzp and ask for a deal without the tune... i have a ppair of led tail lights and halo projector headlights for sale :twothumbs tail lights--https://www.cobaltss.net/forums/part...et-etc-229212/ halo projectors--https://www.cobaltss.net/forums/part...-my-sc-224012/ |
Ok so I guess I'm going with this:
zzp cai & stage 3 intercooler 60 lb injectors 2.8 pulley (don't know much about meth) spec stage 3 clutch trifecta tune oem retrofit(found a good diy kit) led tail lights still haven't found a good exaust thts cheap I want the Hahn but it's really expensive it sounds sexy tho |
You should get a pacesetter header.
I went with the parts in my sig. The car runs pretty good and doesn't get heat soaked to bad. I haven't ran it since I did the intake, but before the intake it ran a 13.6 on a slipping clutch. I wouldn't go any smaller than a 2.8.
ok so i finally decided on my set up
zzp stage 3 h/e 60 lbs injectors ottp stage 2 mounts zzp cai hahn downpipe and shorty header trifecta tune spec stage 3 clutch 2.8 pulley retrofit halos led tail lights what kind of power would i be looking at and are their other mods or parts i should consider to keep the engine in good shape? |
meth injection!!!
No need for meth at all
(Post 5292725)
(Post 5293667)
meth injection!!!
Originally Posted by troyss
(Post 5293681)
psshh hes gunna run a 2.8
and meth always helps on any application, he could be stock and meth will help..... |
Check out www.TurboTechRacing.com we have a ton of great products to help you customize your Cobalt.
Originally Posted by TurboTechRacing
(Post 5293699)
Nice choices, op.
(Post 5293701)
turbotechracing ftw! good stuff there, fast shipping
(Post 5293762)
Thanks!
Ryan @ P&P tuning can do trifecta tunes. He's in Arnold MO let me know if you want his info and I'll PM it to you.
Originally Posted by AndrewSS/TC
(Post 5293810)
Depending on your mileage you might want to consider GM stage 2 if the warranty is important to you...
| All times are GMT -4. The time now is 04:00 AM. |
