No start after clutch replacement... please help
Old May 31, 2020 | 03:54 PM
Dewysslsj's Avatar
Hey guys I have an cobalt ss lsj I just replaced the clutch and now the car will not fire up it rolls over and sputters a bit but won't start I'm getting a code for crank shaft position sensor I changed the sensor and the car still doing the same thing... anybody else ever have this problem?? Any help would be greatly appreciated
Old Jun 1, 2020 | 09:31 AM
jdbaugh1's Avatar
Check your ground that goes from the block/transmission and attaches to the body underneath the drivers side headlight. Make sure it is tight on both ends and making good contact.
Old Jun 1, 2020 | 09:46 AM
Dewysslsj's Avatar
The grounds seam to be ok and tight I will check them again and maybe try cleaning them, I also replaced the front main crank seal but I don't think that would cause the problem...
Old Jun 1, 2020 | 01:11 PM
steelmesh's Avatar
Most certiainly related to something you did. Probably something simple so get in there and inspect everything you went through, don't assume and skip stuff too. A service procedure for that code may lead you in the right direction also. You'll also need to do the relearn procedure but the engine should be running for that.
Don't forget to check all your fuses first
Old Jun 1, 2020 | 01:36 PM
Dewysslsj's Avatar
I have went back over every step I did... I checked all fuses by eye but I will be getting a tester and testing the fuses... the car ran great before the clutch replacement and had no CEL after I got it all back together it won't start and CEL for a crankshaft position sensor...
Old Jun 1, 2020 | 01:41 PM
jdbaugh1's Avatar
Make sure all those little bolts that connect your fuse box to your harness are tightened as well as the ECM connector. Easy to accidentally miss one.
Old Jun 1, 2020 | 02:01 PM
Dewysslsj's Avatar
I have had the fuse box off 3 times now to check the connections and make sure everything was tight that is all good
Old Jun 1, 2020 | 02:05 PM
jdbaugh1's Avatar
Any chance you pinched your crank sensor wire? Did you trace it through the harness and make sure it is in good condition? Maybe inspect the pins on the ECM as well make sure one didn't get bent over or something like that.
Old Jun 1, 2020 | 04:53 PM
steelmesh's Avatar
Post that trouble code. P0315?
Supercharged06SS
Mar 3, 2017 12:48 PM
red70tvhs
Feb 23, 2017 10:54 AM
gomer
Jan 21, 2015 02:59 PM
rekameohs_nire
Mar 7, 2013 11:27 AM
rekameohs_nire
Mar 1, 2013 02:12 PM
