No supercharger coolant.
Okay, thanks for everything guys. I'm gonna go get some coolant from autozone. Dex 50/50 right?
And this might sound like a stupid question, but this is my first car... I just pour that coolant into that same place I just posted the pictures of right? The coolant reservoir for the radiator is separate from the supercharger coolant, correct?
Correct. and yes dexcool 50/50.you can just try straight water to see if there is a leak first.Seeing I live in AZ as well,it's not cold enough to freeze water.You can have the car running while you add to help circulate it and get air pockets out as well
Could I use just regular tap water?
Distilled.You can use tap water but it tends to have calcium build up.
Oh and question,do you have a front lip or is it missing?
Ok I've been seeing a red one out in the gilbert area a bit getting on it everytime he's see's me.One day I'll catch him and give him an asswhoopin lol.
#36
Edit: Come help me with this coolant business ha.
#38
#42
Should say in the owners manual but I can't remember. It probably takes more than will go in right now because if the pump isn't working, it's only going down to the pump and just sitting there, not going into the rest of the system
#47
I'm having the same issue. Not any "curtsies", just no coolant flowing through. What coolant can I use to fill it up? And can I fill it right in that neck in front of the sc?
