Cobalt SS Network
Cobalt SS Network (https://www.cobaltss.net/forums/)
-   2.0L LSJ Performance Tech (https://www.cobaltss.net/forums/2-0l-lsj-performance-tech-47/)
-   -   noisy INGALLs TD (https://www.cobaltss.net/forums/2-0l-lsj-performance-tech-47/noisy-ingalls-td-46347/)
suburbanrobot Feb 6, 2007 02:52 PM
noisy INGALLs TD
It's been super frigid up here in Chicago.... my INGALLs TD is soooo freakin noisy below 30 degrees... it sounds broken!!! The colder it is the worse it sounds....
anyone else have this problem???
ReMz Feb 6, 2007 04:47 PM
a squeaking sort of noise?
OneFast20 Feb 6, 2007 06:31 PM
i hear the same frekin thing, here in akron its been below zero for 2 days and everytime I start up drive it sounds like sqeeking, or metal grinding, but after the car has ran for awhile and warms up it seems to go away...
Video2402 Feb 6, 2007 06:49 PM
Same here, it's cold outside here, and sometimes it makes a loud clunking noise.
SilverSS/SC Feb 6, 2007 06:58 PM
Below 30 or so mine squeaks a bit till the engine gets warm . You oughta hear it now that its been below 0 for a few days , lol ...it squeaks , creeks and makes all kinds of noises when its that cold on almost every bump :D
suburbanrobot Feb 7, 2007 10:41 AM
you got it!!!! I get the loud clunking:thumbsdow and lots of creakin/squeekin .... sounds bad!!!
OK it's not just me!!!
what to do now????? anybody have a fix? any suggestions?
I don't get any metal grind sounds....
xravenwingsx Feb 7, 2007 11:28 AM
awesome, i'm not the only person that's noticed this. :) isn't it the most horrifying sound ever? (well, maybe besides paris hilton singing) ;)
IngallsEng Feb 7, 2007 11:35 AM
Metal grinding sound? I don't think it's the damper's internals, our forged plunger cannot physically reach the side of the damper body. The shaft (yeah, yeah shaft, stiffy...) is also restricted from reaching the inside of the main seal/cap. Metal on metal sound leads me to believe it's something else in that case, but everything else is/could be the damper.
The creaking, clicking, popping are all caused by the shrinkage in the rubber caused by the cold. Our design makes it so the damper is heated by the engine and the heat will bring the rubber back to original design parameters. This takes a little while, but driving a sports car just after initial start up is a bad idea anyway. Our offical response at Ingalls is wait for the car to warm up and drive normally. If you can't wait for the engine/damper to reach operating temp then you can try to increase the preload, but as the car warms up the damper will act like it would with more proload (read: more vibrations).
Dan @ Ingalls Engineering (email: DanJ@IngallsEng.com)
xravenwingsx Feb 7, 2007 11:41 AM
i do let it warm up to ~100-115 degrees before i ever leave my parking spot, but on those -15 degree nights, there's not a lot we can do: i pretty much just grin and bear it. it's a small price to pay for such a high-quality product. as with most modifications on autos: there is always a downside to every part on the market. CAI's give you colder air but are prone to suck up water. 3" exhaust is less restrictive, but from what i understand, lowers your backpressure/low-hp torque. all things we must take into consideration when buying performance parts. the 'stiffy' (uh huh huh..i said stiffy) is an amazing product that i would never ever dream of taking off my car. :D
R33P3R007 Feb 7, 2007 11:46 AM
sweeet.. i was gonna take my car to the dealer for it. i thought i broke sumthing over there. it makes a loud clunk when you get on the throttle. or off it fast. right?
Stilgar Feb 7, 2007 11:46 AM
Its the Dampener, I took mine off and the noise went away. Its gets fucking cold up here -40 with about 20 mph of wind.
suburbanrobot Feb 7, 2007 12:05 PM
Noise dosen't go away after warm up
My noise dosen't go away after engine warm up:thumbsdow .... CED (crate engine depot) had readjusted my Ingalls TD after speaking to someone at Ingalls a few months ago (November maybe).
So what should I do about my noisy Ingalls????
IngallsEng Feb 7, 2007 01:45 PM
Hmm, take a measuring device accurate to half a millimeter (incase you weren't an ME major in college, use a ruler with mm markings on it) and measure from the edge of the damper to the top of the preload plunger. This measurement should be no less than 10mm and no more than 15mm. Most of the Cobalt people I have spoken with tell me that 11-12 mm is ideal for the SC models and 12mm is great for the NA guys. I would tell you to try the 11mm and see if that works for you. Obviously the vibrations in the passenger cabin are unavoidable when you place a force member like our damper between the engine and the chassis. But, clicking or popping tend to stem from the extremely cold winter most have been experiencing.
Good luck and feel free to email me with ANY questions you might have at DanJ@IngallsEng.com.
Thanks.
suburbanrobot Feb 7, 2007 02:03 PM
Thanks.
thanks Dan.... appreciate the follow up:twothumbs .... I'll check it out over the weekend!
J
Mercury Feb 7, 2007 03:04 PM
I took mine off for the season until spring. I don't want these cold temperatures to do damage to my ingalls...
SilverSS/SC Feb 7, 2007 05:00 PM
I havent taken mine off yet . I completely understand the noises are normal , its so cold( single digit day temps , below 0 at night ) here all the squeaks never go away from mine . Am I hurting it at all leaving it on ? By your expaination of the design , it would seem to just be a harmless aggrevating noise , rather than a damaging one
...if the temps are above 20 it does still act like normal and makes no noise with a warm engine . Mine is set at 11mm currently .
BCobaltSS Feb 8, 2007 10:13 PM
Just a side note on these Ingalls TB .Where have guys ordered them from Dezod or Turbo Tech and have anyone had problems with either on geting this part.
This is going to be my next mod but I want to make sure that either one does not scew me over.
sethallen Feb 8, 2007 11:29 PM
i get the same noises as well as a grinding noise when i make left hand turns...and this is at any and all temps
suburbanrobot Feb 9, 2007 07:39 AM
I got mine from DEZOD:twothumbs .... smooth, fast service>>> recommended A+++
I get a multitude of noises from my Ingalls....but, NO GRINDING!!!
my noises occur at 30-35 degrees and below only... very noisey, NO WHEELHOP!!!
sethallen Feb 11, 2007 02:40 PM
Mike Feb 11, 2007 02:50 PM
+1 :twothumbs
Wyoming_Bass Feb 12, 2007 12:25 AM
seth are you sure its your ingalls doing that? i had a bad wheel bearing from the factory that sounds like the problem you are having
ReMz Feb 12, 2007 03:35 AM
i had a topic about this a while ago. never actually took the ingalls off, but i was 90% this was the clunking/squeaking and a few members here had the same problem. this just verifies it..... although the original poster did not acknowledge my post
btw. this is the same post i had a while ago on rockymountanecotec wyomingbass ;)
Wyoming_Bass Feb 12, 2007 04:00 AM
yeah nobody has said anything about it there....
suburbanrobot Feb 12, 2007 09:45 AM
would I be the original poster as I started this thread???
I am very sorry if I did not acknowledge your post.... my apologies!!!!
can you repost (I don't want to dig through all the posts) your post?
you can also e-mail me.....
J
I agree w/ wyoming.... sounds like wheels bearings, CV joint would be clunking!
