Official Turbo LSJ thread!!!
Old 08-18-2011, 05:25 AM
  #176
EXsoccer1921's Avatar
when you go buy your engine. go with a zzp short block if you wanna keep your head. or a long block with the stage2 cams, cam gears, and springs.
Old 08-18-2011, 07:37 AM
  #177
Frew's Avatar
Im going to pick up another stock lsj longblock from scranton this weekend, this will be the motor I turbo. I might also pic up this complete lnf drivetrain that's out in jersey, use the bottom end for a built motor and really turn up the boost
Old 08-18-2011, 08:19 AM
  #178
mexi_loco's Avatar
that's part of my wish list
Old 08-18-2011, 08:44 AM
  #179
jonathan923's Avatar
what did you do about the 20gs internal wastegate? you mentioned you have a 38m wastegate. and how reliable is it the external over the internal?
Old 08-18-2011, 12:01 PM
  #180
Frew's Avatar
I believe external is better for higher boost applications, boost spike and creep
Old 08-18-2011, 12:06 PM
  #181
yellowss7590's Avatar
i have a 38mm external tial wastegate lol. i love it!
Old 08-18-2011, 12:27 PM
  #182
ssyeller's Avatar
Just logging on LSJ turbo 131,000 miles on
Running turbo conversion for 5yrs now. Dyno before last upgrades 325hp. Ported head now, CF hood reverse scoop, larger throttle body, custom intake manifold, and some other little stuff.
question of the day for me is upgrade to 2.2 alternator because when you use 2.0 alternator and delete the old pulley and use a smaller belt you also reverse the direction of the pulley. 2.2 runs the other direction. 2.2 upgrade alternator is also out there as well.
I believe I burned up my 2.0 alternator last night running backwords.
Old 08-18-2011, 01:01 PM
  #183
startingline05's Avatar
so are you saying you have been using the 2.0 alt on your turbo swap for 5 years now?
Old 08-18-2011, 03:33 PM
  #184
I'm too JDM for you
BLAZIN07SS's Avatar
yeah you can weld the clutch on the alt and it'll spin backwards and still work. the problem is the fan is now spinning the opposite direction and it's going to burn up the alternator after some period of time
Old 08-18-2011, 03:39 PM
  #185
BumbleBee's Avatar
The shop in the process of tuning my car (05 lsj turbo) says my pcm is locked. It had GM stage 2 tune on it. Any Ideas? I really don't think it's locked, i'm waiting for their call so they can tell me exactly what it's doing. searching hptuner forums and here as of now. Let me know if you have had any similar issues.
Old 08-18-2011, 03:59 PM
  #186
I'm too JDM for you
BLAZIN07SS's Avatar
it's not locked from GM. they must be doing something wrong
Old 08-18-2011, 05:27 PM
  #187
ULWizSS's Avatar
This
Old 08-18-2011, 05:46 PM
  #188
it could be a conflict ion with the vin is that your original pcm?
Old 08-18-2011, 05:49 PM
  #189
BumbleBee's Avatar
Yes it's my original.
Could it be an HPtuners version issue?
Old 08-18-2011, 05:51 PM
  #190
never mind... yea tuner is doing something wrong...
Old 08-18-2011, 06:13 PM
  #191
new engine going in monday
Old 08-18-2011, 06:18 PM
  #192
your going with the zzp block?
Old 08-18-2011, 06:39 PM
  #193
yeah, its replacing my first zzp block
one car, three engines.. only difference in this one is the valvesprings. going with the gen2 springs they just finished that bind at 520 instead of 450. i waaaas gonna go with the 2.4L forged bottom end instead of another lsj but they're still ironing things out with that combo so maybe next year i'll up it to that.
Old 08-18-2011, 08:31 PM
  #194
did they ever finish testing the 2.4 stroker ( tech 2.3 lol) motor? and your crazy my dude hook me up with your job
Old 08-18-2011, 08:52 PM
  #195
they're still working things out afaik. ive been emailing matt and zoomer regularly with input from todd from time to time and i asked them about switching over to the 2.4 bottom end but they said they're still doing r%d on it after ryans engine failure at CED
i also came across a slew of extended wheel studs that everyone thinks are out of stock
Last edited by EXsoccer1921; 08-18-2011 at 08:52 PM. Reason: Automerged Doublepost
Old 08-18-2011, 09:47 PM
  #196
mexi_loco's Avatar
I'm not 100% sure, but I believe my buddy that did all the fab work just welded the internal wg closed. I'm planning on hitting boost up to about 25-30psi (not on stock internals of course). So an external wg is more reliable in that area as someone already mentioned.
i just had my 2.0 alternator clutch welded so it could run the opposite direction. No problem on it since. And a 2.2 alternator is bi-directional just so you know.
Old 08-19-2011, 04:16 AM
  #197
oh so if its bi that means it goes BOTH ways right
Old 08-19-2011, 09:54 AM
  #198
Frew's Avatar
What are you guys with the s252 et seeing for spool times? Matt M. Told me boost starts coming on good at 3k
Old 08-19-2011, 11:29 AM
  #199
Am not sure about the spool time on that turbo but i say it has to be somewhere between 3500-4300rpms. Ive seen that turbo and its pretty big but that isnt too bad for spool time either. I can have almost full boost by 3200k but then am on a s20g which is also smaller but it deff gives a kick in the rear once you step on it
Old 08-19-2011, 01:51 PM
  #200
my billet 262 starts seeing boost around 3400, 10psi at 4600, 23psi at 5100, 31.5psi at 5500
Quick Reply: Official Turbo LSJ thread!!!
