Official Turbo LSJ thread!!!
Old 03-04-2014, 05:16 PM
  #7751
Bad-A-SS's Avatar
Ok guys quick question, i got stage two cams, springs n retainers, and nbs ordered from josh should i being on the safe side upgrade my fueling while I'm at out or do y'all think if i stay around 16-18# i should be fine? I'm good as of now and I'm on 14# and pretty rich
Old 03-04-2014, 05:24 PM
  #7752
574
574's Avatar
When modding the saab intake manifold, I know you drill the bolt holes out, zzp said they added vac ports, but under the description they also say drill and tap underside of manifold for map sensor. But why because isn't there a spot right on top for that?
Old 03-04-2014, 06:04 PM
  #7753
Bass_Waves's Avatar
Don't think so. I'll double check mines. Iirc its closed off like welded off. The map sensor is at the bottom.
Old 03-04-2014, 06:39 PM
  #7754
574
574's Avatar
Thanks, if anyone has a picture that would help a lot.
Also looking for an le5 tb because mine was throwing a code in the fall so I think I'm just gonna make the switch
Old 03-04-2014, 07:25 PM
  #7755
armcclure's Avatar
1: the harness won't reach
2: the hole is too shallow. The tmap won't fit. Only a regular map.
Just send the mani to me. I'll take care of it.
Old 03-04-2014, 07:27 PM
  #7756
SmitBag's Avatar
parts purchased, slobalt will be turboed here in a couple weeks
Old 03-04-2014, 07:43 PM
  #7757
574
574's Avatar
you will love it
Old 03-04-2014, 07:53 PM
  #7758
EXsoccer1921's Avatar
I forgot what boost felt like
Stuck watching old videos of the car haha.
Old 03-04-2014, 09:23 PM
  #7759
BlkWdoSS's Avatar
False. Resurface after welding, coat with antiseize so it can self align, and you're good.
nope even with slip pipe and gasket they leak, pop a hood on any semi truck in the country and you will see, they all have soot on them from leaks
Mark, I forgot what boost feels like too
Old 03-05-2014, 07:17 AM
  #7760
bmxracerchamp12's Avatar
i will dig mine out of the closet tonight if i remember
Old 03-05-2014, 09:03 AM
  #7761
asherby85's Avatar
It's not turbo lsj, but you know you can always drive my car babe.
Old 03-05-2014, 09:07 AM
  #7762
havent seen that name in awhile lol
Old 03-05-2014, 05:59 PM
  #7763
BlkWdoSS's Avatar
She has been busy lol
Old 03-05-2014, 08:18 PM
  #7764
Thanks honey.
Old 03-06-2014, 05:38 AM
  #7765
armcclure's Avatar
By car does she mean vagina
Old 03-08-2014, 09:03 PM
  #7766
Bass_Waves's Avatar
damn. i dont know if this is normal. 256et. took off my intake to do a pvc upgrade. felt the turbo . a lot of up and down movement. does not contact the walls yet. no in and out movement yet. 542 miles on turbo and kit. >.<
normal? to me hell no
i been trying to go e85.
i have the 80# injectors. stock pump
fuel pump wiring kit going in
next purchase would be what? brfps? pump? any opinions. i did a google search and got no conclusive results.
Old 03-08-2014, 11:08 PM
  #7767
Bad-A-SS's Avatar
What year do you have? 05 pumps were supposedly quite a bout weaker than 06-07
Old 03-08-2014, 11:10 PM
  #7768
Bad-A-SS's Avatar
As for the turbo shaft movement you will most likely have to show us just how much movement is going on. So just post a video please if you can
Old 03-08-2014, 11:33 PM
  #7769
Bass_Waves's Avatar
K I'll get a video tomorrow. I got to rerout the PVC system.
Mines a 07
Old 03-08-2014, 11:43 PM
  #7770
Bad-A-SS's Avatar
Mines a 07
Good man thanks and you should be fine so don't replace until you absolutely have to
Old 03-09-2014, 01:55 PM
  #7771
BlkWdoSS's Avatar
already drove that, hence she is in her current predicament
Old 03-09-2014, 04:33 PM
  #7772
Bad-A-SS's Avatar
Hey blkwdoss when you coming up to Carolina to build an engine with me lol
Old 03-09-2014, 08:31 PM
  #7773
i944scania's Avatar
So my car has a weird evap thing going on. Have you guys had any issues with your evap system? Here is my post in tuning:
https://www.cobaltss.net/forums/show...99#post7295499
Old 03-10-2014, 09:50 AM
  #7774
BlkWdoSS's Avatar
lol, you should bring it here since all of my tools/equipment are here
Old 03-10-2014, 01:32 PM
  #7775
574
574's Avatar
Guys with saab manifold, what do you do with the brake booster line?
Quick Reply: Official Turbo LSJ thread!!!
