Official Turbo LSJ thread!!!
Old 03-06-2012, 06:08 PM
  #1576
Rattlesnake Race Shop
USMCFieldMP's Avatar
Originally Posted by BlkWdoSS
What is the new setup going to be like?
there is absolutely no room for an intake pipe on this thing right now so the pump is the only route I can take.
What are you going to do with the pump?
Im really thinking I may be able to wire it in where my old IC pump was and I can control it with HPT...
l8r,
PD
New set-up will be simple. ZZP Mani, PTE Billet 5557, Recirc Downpipe.
I'm not going to do anything with the pump. That's what I was getting at. You can have it if you want.
You can put it where the old IC Pump was... but you just that it is quite a bit larger than the stock I/C pump. The plug should actually be the same... but I would run it off of a Hobbs switch set for something like 5-10psi. You don't want it running all the time. Which is basically the extent of your control of it via HPT.
Originally Posted by SCcobaltSS
Why cant you fit an intake?
Because of his turbo manifold. Positions the turbo in such a way that its basically impossible.
Old 03-07-2012, 03:36 AM
  #1577
BlkWdoSS's Avatar
Ill take it lol. I have a Hobbs switch coming for my new valve so I can set up a line from that to activate the SAI.
As far as control from HPT, I was wanting to be able to activate it prior to a pull, then a few moments after the pull shut it off. Im tired of the smoke in my exhaust sitting in traffic after driving for a bit, its quite embarrassing. So I could turn the pump on and off during those times.
Chris, Ill have to shoot sum pics over for you to take a look. The exhaust manifold clocks the turbo to be perpendicular to the back of my block. The compressor housing faces the block with about 4" from block to compressor inlet. The only filter Ive seen that could work is the HKS style but from my measurements itll hit my intermediate shaft. SO... stuck with running a mesh screen/meshing over the inlet.
l8r,
PD
Old 03-07-2012, 11:17 AM
  #1578
SCcobaltSS's Avatar
l8r,
PD
Ah ok that makes sense. I just thought when whoever was creating that they would have left enough room for an intake. Is it just because you have a beast turbo? Has anyone with this header been able to fit? I know there is only a couple out there.
Old 03-07-2012, 11:47 PM
  #1579
sscarlos027's Avatar
ok so im almost done with my turbo biuld all i need is the belt i have a belt on right now but its a little big and the alternator its not chaging and its killing the batery if someone can tell me the size belt i need it would help alot all i need is the belt to tune the car thanks
Old 03-07-2012, 11:56 PM
  #1580
Facepalm_IRL's Avatar
as blkwdoss told me the other day you can order it from napa. get the part number for a 2.2 belt. the change the first 2 numbers for "05" to "06" that determines the number of ribs on the belt. It should fit perfectly
Old 03-07-2012, 11:58 PM
  #1581
i tried a 2007 2.2 and 2.4 belt they are to short
Old 03-08-2012, 12:03 AM
  #1582
hmmm...im sure blkwdoss will be on later and can sort out my issue with my statement, as im sure others can help with this belt issue. I too am building my own turbo swap and that was going to be my route for a belt. if all else fails, i wonder if the tensioner/belt combo from the saab 9-3 turbo would work. Those were the "original" turbo lsj if i remember correctly. Just food for thought.
Old 03-08-2012, 12:07 AM
  #1583
man ive been goin crazy with the belt issue the car runs great all it needs its the belt thanks for the help man
Old 03-08-2012, 12:08 AM
  #1584
SCcobaltSS's Avatar
I used a 2.2 belt with no issue. You are using a 2.2 alternator or welded the pulley on the lsj right?
Old 03-08-2012, 12:10 AM
  #1585
what year belt ??
Old 03-08-2012, 12:14 AM
  #1586
they are all the same
Old 03-08-2012, 12:15 AM
  #1587
SCcobaltSS's Avatar
See my additional comment
  #1588
its to short i have stock alternator with a clutch on
Old 03-08-2012, 12:19 AM
  #1589
i have stock alternator with a welded pulley
Old 03-08-2012, 12:22 AM
  #1590
SCcobaltSS's Avatar
Put belt conditioner on it, see if it helps. You hear it slipping? I got an 06 even though it shouldn't matter.
Old 03-08-2012, 12:25 AM
  #1591
yeah man it slips its not tight at all
Old 03-08-2012, 12:26 AM
  #1592
SCcobaltSS's Avatar
Maybe your tensioner? New?
Old 03-08-2012, 12:32 AM
  #1593
i dont think its the tensioner
Old 03-08-2012, 12:39 AM
  #1594
SCcobaltSS's Avatar
If its actually a 2.2 belt its gotta be something else.
Old 03-08-2012, 12:44 AM
  #1595
the one that its on the car now its not the 2.2 belt is one that i bought like 10 diferent ones and that one was the tighter but i need one more tight
Old 03-08-2012, 12:47 AM
  #1596
maybe your routing is messed up?
Old 03-08-2012, 01:01 AM
  #1597
SCcobaltSS's Avatar
From the picture it looks correct. Something has to be up.
Old 03-08-2012, 01:03 AM
  #1598
SCcobaltSS's Avatar
You can actually see the belt moving when its turned on right?
Old 03-08-2012, 01:18 AM
  #1599
yes when the car its on you can see it slip
Old 03-08-2012, 01:20 AM
  #1600
Maybe the tensioner is totally like not applying like da tension...ya bra
Quick Reply: Official Turbo LSJ thread!!!
