Official TVS Thread!!!
Old 04-05-2012, 08:03 PM
  #226
Sully20's Avatar
[QUOTE=Bluelightning;6431810]You already have all the supporting mods so I would pick up a used TVS if I were you. If you are 30 minuites away for meth and E I would run meth. Just buy 5 gallons at a time and run 50/50. It would last you a while.
No I hear ya and you guys are def swaying me to just getting a used TVS and believe me I wouldn't mind going that route, Its just honestly I got beat today by a sick Mercedes Benz and it pissed me off and realized that I need to upgrade in one way or another, Blue you def have a valid point about the supporting MOD's, But its almost like a whole new setup with needing 80's, TVS, METH, Cause If I get a TVS I will want to run prolly a 2.7 and I'm just assuming that I'm gonna need additional cooling for that pulley size, Also scared about spraying pre-blower as I've heard horror stories about the bearings in the TVS.
Old 04-05-2012, 08:07 PM
  #227
Sully20's Avatar
Since you guys pretty much all have the TVS, In your HONEST opinion is it REALLY Worth the Money? I mean your at least looking at $1,200 Used and it makes what Approx 30WHP over the Eaton? Correct me if I'm wrong.
Old 04-05-2012, 08:48 PM
  #228
mrbelvedere's Avatar
on a stock engine the tvs is worth 100hp on a modded engine depending on fuel used well more then 30hp
Old 04-05-2012, 08:59 PM
  #229
Got Bewst?
Bluelightning's Avatar
You can run 60's on pump gas. The best cooling you can run is water/meth. Heat exchanger, dual/single pass arent crucial but nice to have doing back to back pulls. But you already have them so you are set. Don't be scared about running meth through the TVS. There are people that have blown bearings not running meth through it. I've run meth through my M62 for 2 years. Zero issues and the coating on the rotors is still mint. But if you buy a brand new one it will void your warranty.
Old 04-05-2012, 09:47 PM
  #230
carstedt's Avatar
ive ran meth on my m62 and my tvs and never affected either of them
Old 04-06-2012, 10:46 AM
  #231
Window Licker
sjc0013's Avatar
It's worth it, even if you're conservatively tuned, it pulls like a mother
Old 04-06-2012, 03:51 PM
  #232
USA Y U NO HAVE AUTOBAHN?
tylerjclance's Avatar
new breather
Old 04-06-2012, 03:52 PM
  #233
TStone's Avatar
Got tuned for my 2.6 today........ I don't think I really need to say much more..
Old 04-06-2012, 03:54 PM
  #234
[QUOTE=Sully20;6432317]
I have a heat exchanger and duall pass, not installed yet, lazy,
I just replaced my IC pump, using a 2.7 on the TVS with methanol a pull from second all the way into fourth, IAT2's get to about 130..
Drop back down to 80 (25* above air temperature) within a minute after the pull..
The cooling mods aren't really that necessary, unless you're doing back to back pulls.
Old 04-06-2012, 04:21 PM
  #235
InfraRedline's Avatar
Are you still on your stock pump Infra?
Yes currently I am :/
Old 04-06-2012, 06:39 PM
  #236
Originally Posted by tylerjclance
new breather
i wouldent run that breather it will can cause a lean condition unless tuned for it
Old 04-06-2012, 08:25 PM
  #237
Got Bewst?
Well I got my GMPP clutch in today! Not too bad of a job at all! Break it in in the next couple weeks then bolt up the TVS
Old 04-06-2012, 08:56 PM
  #238
574
574's Avatar
Aren't you worried about running a 2.6???
Old 04-06-2012, 10:06 PM
  #239
Rent me! per hour
Area47's Avatar
congrats on your air leak
Old 04-06-2012, 11:23 PM
  #240
lmao yup
Old 04-07-2012, 12:00 AM
  #241
SunburstSS's Avatar
Gonna tune mine tomorrow and possibly hitting the rollers next week
Old 04-07-2012, 05:48 AM
  #242
I disconnected the sensor in the header and plugged my wideband into there. Is that ok? LOL
The stock sensor on the downpipe is after the cat, so it would be useless to plug the wideband in there.
I get a CEL, clear it with the interceptor.. good to go until i turn it off and on again. LOL
Old 04-07-2012, 05:50 AM
  #243
Then what's the purpose of having the breather?? LOL
Old 04-07-2012, 07:22 AM
  #244
RooTBeeR's Avatar
looks like you're gonna have your hands full tyler
Old 04-07-2012, 08:24 AM
  #245
new breather
see that hose on the back of the valve cover that runs over to your intake well that creates a vaccum draw in the valve cover. with the breather in place and that hose still hooked up your creating a big vaccum leak. now the engine is pulling unmetered air in through your breather
Old 04-07-2012, 10:32 AM
  #246
Dontstoprunning's Avatar
How many of you guys are running a catch can?
Old 04-07-2012, 10:45 AM
  #247
"Chrome Valve Cover Breather that simply replaces your oil cap on your valve cover. Used to let air into the crank case on supercharged engines or to vent crank gases on engines with aftermarket power adders."
Then why would ZZP sell it if it's only going to cause problems?
Old 04-07-2012, 10:49 AM
  #248
It does say it's a must have for a turbo converted car.
But also says it's useful for supercharged engines.
Old 04-07-2012, 10:51 AM
  #249
I understand how it can create a vacuum leak, i just don't understand why zzp would sell it, or why it would even be made in that case.
Old 04-07-2012, 12:32 PM
  #250
advise's Avatar
its not that it doesnt work yours in not installed correctly
you should remove the breather filter and run a catch can
or remove the breather line and run just the filer
either way the filter still wont because the pcv in the head
Quick Reply: Official TVS Thread!!!
