Originally Posted by ebristol
(Post 6419080)
I think that would be more then enough. If your base is 58 then your actual FP under boost should should be about 78-80psi which Should be plenty. If you have to run it that high to get enough fuel then upgrading your pump would be a good idea.
I would recommend starting at a base of 50psi. That is where I plan on starting...I guess we will see. I want to take a long drive just to get this dino fuel out of my tank! just disconnected the line on the rail and jump out the relay lol |
(Post 6419010)
Well the 06+ LSJs have a pretty decent fuel pump. I plan on running a 2.7" on my TVS, E85 and RSFS. I am pretty sure I should be okay.
Does anyone else have any input? I will be running E70 winter blend shortly. I will keep this thread updated. |
what base pressure did you run
(Post 6419069)
haha i'm just lingering for now. thinking of going with a lysholm and 500+
I'm about to pop zzp stage 2 cams in with mine plus a ported single pass intake Mani...will post results soon :-)
Originally Posted by G11
(Post 6419342)
define soon :) |
Originally Posted by BlackMagic
(Post 6419305)
Serious?
(Post 6419354)
yes?
depends if i switch fuel systems or not. if i go with 190s and a dual pump setup then yes i'll stay turbo cause then i'll be able to run about 35-40psi on alcohol. which would be 650+ if not 700. but if i keep the current setup then i'll debate on going with the lysholm at 500-550..
550sc>591tc. |
don't even think about it.. go the sc route !
well i'm already over a hundred horsepower higher than that best sc numbers... so if i redo the fuel system i'm def staying turbo.
(Post 6419451)
Originally Posted by advise
(Post 6419254)
Originally Posted by alleycat58
(Post 6419665)
That I do not know, tuning gurus handled fuel and tuning. I'll ask though.
you all are trying to run to high of a base pressure start mid 30s but dont go past mid 40s
(Post 6419456)
I would love to see a 550whp blowered balt. You may make more power with the turbo yes but you would definitely be different supercharged.
Originally Posted by TStone
(Post 6419348)
gasp..
define soon :) |
(Post 6419840)
I get the single pass tmrw and came within the month unless I do new wheels
(Post 6419918)
Wheels aren't necessary. You already have wheels. Get cams!
I still got about half a tank... I should fill up with E85 and try a 50/50 blend for the heck of it.
Getting on the dyno next week. Kinda pumped and kinda nervous. I don't wanna see numbers lower than the ones I've fabricated in my head. :lol:
Haha what's your mod list? Sorry if you have it in your sig, I'm on mobile
TVS
80lb injectors Injen CAI Pacesetter Header Custom 3" dp 2.5" Magnaflow Exhaust to Borla Muffler Dual Pass Stg 3 ZZP H/E Option B 2.8" Pulley 50/50 Methanol HP Tuned |
Oh boy.. better keep us updated with what you makeee
Hah, why "oh boy"?
