Oil.!?
Ok so when i got the car they changed the oil and everything but i look up today and finally notice the little sticker and it says 5w-20. Is it o.k to run this through the car or should i change it out as soon as possible?
you won't really hurt it i don't thin, but 5w30 would make your motor happier.
Probably not a good idea to run 5w-20 in the LSJ. The oil is too thin and viscosity will be too low for the LSJ. It isn't going to hurt anything in the short term, but you wouldn't want to run it all the time and definately not if you are running it hard.
