Option B Problem.. Tank Fills up.
Having this problem. See video. It should explain the issue pretty well.
Car is off the fluid flows down and fills the HE up... Car is on(pump is on) HE drains down some and OPT B. tank fills up to top which is thus replacing the air which is then going into the top of the HE.
Flow of pump is correct. No kinks, no leaks. Plumbing is correct. Mods are ZZP Stealth(no stock HE), Dual Pass, Phenolic.
I had this issue. Swap the in and out at the pump. It should be heat exchanger out to middle of dual pass. Then top and bottom of dual pass go to the pump sticking sideways. The pump facing up go to inlet of heat exchanger. Opt b connects to a T or Y where the top and bottom of dual pass are plumbed together that lead to the pump nipple sideways.
The orifice is installed. So... I've plumbed to the EXACT same was as the diagram above. IC pump is working, and it bleed air the correct way. It is no longer filling up the OPT B.... HOWEVER...
Cruising IAT2's are 110* Any help here?
If I pop the cap on my ZZP Stealth while car is on it overflows like a **** since the pump is flowing it that way I assume.
Also, there is a constant flow of coolant through the bleeder line.
Mods: ZZP Stealth, Dual Pass, Phenolic, Opt B.
This is worse than before I even fucked with the Opt. B BULL ****... Getting tired of this crap.
Grabbing a video right meow.
There should be no flow into the option b tank from the 3/4 inch hose as its not a flow through setup! Sorry Panther lol
It is simply an overflow for expanding fluid. So you do not have the stock h/e at all? That may be your issue. My iat's are 20 degrees apart when cruising. I will see 130-140 degree iat2 temps when driving in traffic but the quickly go down when you get a nice uninterrupted stretch of road.
It's not going to keep you iat2 at ambient as the supercharger is using recycled air at idle and it just keeps heating it up while its idling if that makes sense
Take a step back from it, and calm down. We will help you get it figured out.
Powell, watch that second video I explain and show everything. I'm confused on what I've plumbed wrong. Looked at it with a few local LSJ's as well. Everything seems perfect.
I did watch is get a TON of air out when I had first start-up with the new plumbing.
