OTTP A/C Condensor Brackets
Hey Guys, I wanted to know if I don't want either ZZP S3 or OTTP S1 Heat Exchanger. I want to use just OTTP A/C Condensor Brackets to move my A/C Condensor out but same stock Heat Exchanger to get more cool air coming through. Will that work to cool stock heat exchanger? I am on 2.9 pulley, option B tank, dual pass, phenolic spacer is in my car. I know the more cooling the more better. What you guys think ?
not worth the effort to move it out as it wont make much of a difference. But try it. You dont need brackets, just bend the upper tabs on the ac condensor and put a spacer in the lower one...
Cause, I was thinking A/C condensor is in the way and it's blocking some air that is going through to heat exchanger. That's why I am saying to move A/C condensor out alittle and let more air go through to heat exchanger like let it breath. Instead of A/C condensor is too close to heat exchanger then that's the problem cause it's not getting much air to cool it down.
I remember someone relocated the Stock HE in front of the AC condenser. But I never saw pics or any details on it.
Does it prove to cool IAT down ? Or better off getting ZZP S3 Heat Exchanger ? But if I move A/C condensor alittle and put ZZP S3 Heat Exchanger. I think it will cool WAY down more than you even know. Doesn't hurt to try that out. AW HECK! I'm gonna do this.
| All times are GMT -4. The time now is 11:04 AM. |
