P0069 baro absolute manifold pressure. code 05 cobalt ss lsj
Old Nov 13, 2013 | 11:13 AM
kobe77's Avatar
I have an 06 ss/sc stock m62 car has a gm stage 2 with factory recalibration tune. Exhaust is stock. The car runs great, has plenty of power oil has been changed at regular intervals while in my posession. I have no explanation for this code, I'm wondering if anyone has experienced the same and knows a potential solution for my issue. Thanks.
Old Nov 13, 2013 | 11:39 AM
mrbelvedere's Avatar
try checking wiring to the sensor if that is good swap it out and try posting in the correct section its called problems and service
Old Nov 13, 2013 | 11:44 AM
kobe77's Avatar
Ok thanks I will check that. Just did a compression test last week 185/185/185/185 and a vacuume test which presented no leaks. Is that a high compression? I knew it was a bit over but wasn't convinced it was an issue. Might rip my head off and inspect my valves, seen a post that said someone turned up a cracked valve from this code. Think I'd have noticed it tho
Old Nov 13, 2013 | 11:48 AM
190 to 210 is ideal but in reality anything above 180 is going to be good there Is no need to remove the head at this time so don't fix what is not broken
Old Nov 14, 2013 | 09:51 AM
kobe77's Avatar
True enough. Thanks man
Spanky's Monkey
Mar 7, 2016 06:06 PM
Supercharged06SS
Oct 5, 2015 09:13 PM
vjoel2011
Oct 2, 2015 12:11 PM
twilson380
Sep 14, 2015 10:52 AM
Josh@ottp
Sep 8, 2015 10:18 AM
