Cobalt SS Network
Cobalt SS Network (https://www.cobaltss.net/forums/)
-   2.0L LSJ Performance Tech (https://www.cobaltss.net/forums/2-0l-lsj-performance-tech-47/)
-   -   p0420 code, help (https://www.cobaltss.net/forums/2-0l-lsj-performance-tech-47/p0420-code-help-72662/)
scotts2.0 Aug 21, 2007 05:06 PM
p0420 code, help
I have a ZZP DP with high flow cat. I have had this set up for about three months, no problems. three days ago, I start getting the CEL p0420, catalytic insufficiency. the only thing i have changed since the DP install is a coolingmist injection. Any suggestions on what is causing this CEL and what i can do to fix it. I've reset the code about 4 times now. Keeps coming back
thanks
Area47 Aug 21, 2007 05:11 PM
that code does not hurt anything. the rear 02 is calibrated to the stock cat. not a high flow.
hence why you get the code.
scotts2.0 Aug 21, 2007 05:14 PM
I was running fine for three months, no codes ever, why all the sudden now?? Any ideas
Area47 Aug 21, 2007 05:21 PM
some cars are instant on it, some take time. clear it, and go about your way
fballman1987 Aug 21, 2007 09:14 PM
yea my subaru throws that code its just the sensor, clear it and move on
XM15 Aug 21, 2007 09:17 PM
I get that sometimes with my vibrant dp.
Thats what I do too.
zinner Aug 21, 2007 09:23 PM
I have had the ZZP hi flow car for over a year now with no code, the cat could be shot.
The computer is tell you the CAT isn't doing it's job. The 2 O2 sensors produce a SINE wave and if the two sensors match that means the CAT isn't doing it's job any more and the code is produced.
You won't pass emissions with that code, no matter how many times you clear it, because the OBDII tests will never complete.
fballman1987 Aug 21, 2007 10:36 PM
i have actually been throwing that code randomly in my subaru it would come on and go away its come on so many times i dont even bother with it any more, but i just got the car inspected and it did pass emission, granted the light wasnt on but that wont change what its like in the cat.. idk maybe i just got lucky.
scotts2.0 Aug 22, 2007 04:53 PM
everyone, thanks for the feedback. Looks like I'm stuck with it for now. Seems to be running OK.
fballman1987 Aug 22, 2007 04:56 PM
yea it should run okay your are probably going to see a decrease in gas mileage though, thats one thing i forgot to tell you.
Corvettespirit Aug 22, 2007 05:07 PM
Dtc P0420.catalyst System Low Efficiency:spam:
Stouffer Aug 22, 2007 05:16 PM
Fortunately I haven't seen a decrease in gas mileage
I have cleared the stupid code 3 times but keeps coming back, the car runs fine, just get used to the CEL.
Corvettespirit Aug 22, 2007 05:21 PM
Conditions To Running The Dtc;an Engine Misfire,high Engine Oil Or Coolant Consumption,retarded Spark Timing,a Weak Or Poor Spark,a Lean Fuel Mixture,a Rich Fuel Mixture,a Damaged Oxygen Sensor Or Wiring Harness,the Catalyst Test May Abort If The Vehicle Falls Out Side The Conditions For Running The Dtc,a Catalyst May Be Temporari Degraded If A Fuel With High Sulfur Content Has Been Used.:confused: ?
fballman1987 Aug 22, 2007 05:26 PM
your lucky im filling up my subbie about every three days, its getting about 230 miles to the tank, i think it should be getting almost 280-300...
RedEcotecSS Aug 22, 2007 09:21 PM
i got this code instantly with my ZZP DP.
Shack63 Aug 28, 2007 10:19 AM
Same error, here's something to try
I'm getting this same P0420 dtc using Hahn Racecraft header and hi-flo down tube.
You can use your VCM Editor, like HP Tuner, to change the error limit or disable it. By default it's set to 0 - MIL on first error. Hope this helps.
