Phenolic spacer
I will be installing a phenolic spacer shortly with the 2 paper gaskets. Are the paper gaskets sufficient without any RTV or anything?
I wouldn't waste your time with those silly phenolic spacers. They have never work great and most users ended up experiencing a vac leak due to poor sealing.
I haven't had an issue with mine, but the only reason I run it is to bridge the difference between the base and the lsj pcv ports together. I milled a channel into the spacer. I used copper rtv spray on both sides without a gasket and haven't had any issues
The paper gaskets and rtv work fine, even used them without the spacer. What mike said is true but you can also acheive this by cutting a channel into the manifold flange itself.
(Post 7632023)
Originally Posted by 07blackg5
(Post 7632041)
(Post 7632049)
Originally Posted by jdbaugh1
(Post 7632072)
I'm doing the same thing. To clarify you used the RTV and didn't use the paper at all?
https://cimg5.ibsrv.net/gimg/www.cob...0490b77b3f.jpg put many light coats on it until i could tell it had a nice even layer on it and let it tack up. when i torqued the manifold, A very tiny, continuous, uniform bead worked its way out around the spacer on both sides. |
(Post 7632073)
But when you cut a channel into the manifold the stock metal gasket doesn't have provisions for this. If you just slot out the gasket you wouldn't get a good seal. I would think you would have to use some sort of RTV to make it work properly this way as well.
(Post 7632082)
correct.
I rtv the supercharger and IM on lol, prybar does wonders
I used the factory metal gasket and 1 paper gasket and have not had any issues.
I only run the spacer on the throttle body because pwerks didn't have the manifold one available when I ordered.
Have 1 on my lsj and it works great, raises the supercharger up as well.
| All times are GMT -4. The time now is 12:27 AM. |
