Piston rings and gaps
Old 01-09-2009, 01:30 PM
SSdan's Avatar
What are you guys with aftermarket pistons/rings are you gapping the rings at? I've been thinking of running stock rings with 18-21 ring gaps. What about total seal rings?
Old 01-09-2009, 02:45 PM
Witt's Avatar
What pistons are you using?
The stock rings will only fit the aftermarket Mahle pistons, the ones that use a different piston pin diameter iirc.
If you are using Diamond off the shelf pistons use either one of the following ring sets from total seal:
CR8674-40 Classic race conventional ring kit
X8674-40 Gapless second ring kit
MX8674-40 Gapless top ring kit
I use CR8674 40 with .018 gapped top ring, .012 gapped second, .015 oil control gaps. The last two engines I built are using those rings with those gaps, one holds 32psi boost from a turbo, the other 25psi from a TVS. No popped dipstick/crankcase pressure problems or excessive knock/carbon buildup in the CC.
Old 01-09-2009, 02:58 PM
SSdan's Avatar
Perfect. Kudos to you my friend.
Thanks
Old 01-10-2009, 10:34 AM
SSdan's Avatar
Witt do you get any ring flutter between the first and second rings? I've heard having a tighter gap on bottom cause ring flutter between the two.
Old 01-10-2009, 10:46 AM
M88ArRamadi's Avatar
https://www.cobaltss.net/forums/show...ht=piston+ring
Old 01-10-2009, 03:22 PM
Witt's Avatar
No crankcase pressure or oiling problems what so ever.
The gaps I gave you are based on Total Seal recommendations for those rings as follows:
(these apply to the Classic Race and gapless 2nd rings, gapless top will require larger gaps)
top ring: (3.385)x.0055
second ring: (3.385)x.0035
oil control: .015
When you buy the rings they will come with a guide on an orange paper stating the same.
Old 01-10-2009, 04:02 PM
Sharkey's Avatar
when i built my friends 2.2 eco i followed the total seal directions to a T. ended up going .018 top and .011 on the 2nd, and a .013 on the oil controll. put 10k km on it running 12psi, no issues. have the car apart for winter, going to do a leak down test tonight just to see what it looks like.
Old 01-10-2009, 04:23 PM
SloBaLt RiDeR's Avatar
well hope the diamond pistons come with a guideline cuase i order mine today
Old 01-17-2009, 10:24 PM
KawBoy's Avatar
Anybody mind explaining why you would run a larger top ring gap then bottom?
05-28-2022 03:47 AM
Turbo Johnny
02-21-2019 09:41 AM
ineedacobaltss
11-07-2015 02:25 PM
HEATON
10-16-2015 07:21 PM
SlowSaturn
09-28-2015 11:03 AM
Quick Reply: Piston rings and gaps
