Please help!
Ok so i'm installing my zzp S3 heat exchanger and I finnaly got the bumper off and about to mount everything but I was wondering if i must drain all the coolant? and when I unhook the pump and hoses will it spray everywhere? Also How much will I need? I bought a gallon of Dex Cool and 2 gallons of distilled water. Help and advice is much appreciated thanks alot!
anyone? |
Originally Posted by jmo2010
(Post 5157153)
anyone? |
if you bough the 50/50 mix you will not need to mix the coolant with the water...also take needle nose pliers and pinch the hose so it wont bleed out everywhere. I just installed mine 2 weeks ago and only lose not even 1/4 of a quart of coolant...hope that helps
after you get it hooked up, fill the coolant neck up to the top and start the car. as it runs the level will drop. just watch it and as the coolant drops keep filling it back up
ok thanks. Well I got everything setup, except i didn't set my car on jack stands so I will have to finish tommrow lol. And ya I bought dex cool and a couple gallons of distilled water and am going to finish that puppy off tommorow. And I have a zzp kit, it came with a good length of hose, should i cut this and use it for both or should I use one of the stock hoses from the exit from stock h/e to the zzp? Thanks alot everyone. I just like to double check lol
| All times are GMT -4. The time now is 10:59 AM. |
